Samsung SP0812C. Run 5 secind and stop....Why?
April 22nd, 2008, 13:21
I have a hdd Samsung SP0812C and it run 5 secunds and stop motor, what soukd to be the problem ?, This problems can to be the PCB or Media , Head, ????
Steve
Re: Samsung SP0812C. Run 5 secind and stop....Why?
April 22nd, 2008, 14:48
Connect to terminal and check the error condition (code after LED) please post terminal log.
April 22nd, 2008, 15:56
could be the preamp .
April 22nd, 2008, 18:17
Hi
If it is not clicking in that 5 seconds, the problem is probably FW related.
April 23rd, 2008, 4:56
Hi, I connect to PC but It is not recognized for the bios, how can I to see the terminal log ? Do you thinks the problem is on the PCB, the hdd not make a click sound, run 5 secunds and stop the motor.
April 23rd, 2008, 13:45
If u connect it to PC as secondary master and run MHDD, what do U see on the registers at the top of the screen?
April 23rd, 2008, 14:35
I can see the Mhdd but the secund hdd (Samsung Failure) not show anything.
April 23rd, 2008, 15:18
Surely it won't show the ID, I was asking about the status register. U can see its bits in the upper left corner:
[BSY][DRD]...
which one is lit up?
