 Post subject: N40P firmware
PostPosted: April 25th, 2008, 0:20
Hi gurus
I am dealing with a maxtor N40P. I have identified problem with the firmware & correct rom checksum with loader. Now i need to write 3 bad modules - 02C00002 , 00090020 , 00290139. rom checksum of patient is 639E
What criteria i must look while choosing right firmware ( from donor) .If someone has right firmware please pm me.
Thanks & Regards
Hddbug
 Post subject: Re: N40P firmware
PostPosted: April 25th, 2008, 5:10
It seams we cant write mod 0009 (zone table) from another drive couse it is esencial one....
Am i wrong...?
PostPosted: April 25th, 2008, 5:23
Hi trubarevacki
Thanks .Yes this module cannot be borrowed.What will be best option for me?
Thanks & Regards
hddbug
PostPosted: April 25th, 2008, 5:41
I don't know, sorry..
Maybe some of the guru's here?
PostPosted: April 25th, 2008, 6:24
nobody here.. Well, translator regeneration allows to rebuild translator modules based on the data found in general defect list ( RZTBL is one of them).
PostPosted: April 25th, 2008, 7:18
Thanks a lot trubarevacki .
I am getting maxtor Techno command error with typical UBA8 error. Here is log -
Read roadmap............................ : Ok
Read roadmap extension.................. : Ok
Read zone allocation table.............. : Ok
Read Technological ID................... : Ok
Read Zone allocation table extension.... : Ok
SA head................................. : 3
Ext Model............................... :
HDD has an alternate service area
HDD structures have been read successfully
SA structure test
Selected family ........................... N40P
Model ..................................... Maxtor N40P
Firmware .................................. NAR61590
Serial ....................................
Min. cylinder ............................. 0
Max. cylinder ............................. 4294967295
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 5
HDD configuration module
Error ..................................... UBA 8 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6À]
Checking User data adaptives
Header .................................... CR0TF`
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 352: 411: 540
2 : 412: 5278: 1140
3 : 5279: 11018: 1125
4 : 11019: 16642: 1105
5 : 16643: 29027: 1080
6 : 29028: 34922: 1044
7 : 34923: 40236: 1020
8 : 40237: 46449: 990
9 : 46450: 51301: 960
10 : 51302: 54738: 936
11 : 54739: 61793: 900
12 : 61794: 65428: 864
13 : 65429: 68486: 840
14 : 68487: 72980: 810
15 : 72981: 76346: 780
16 : 76347: 79589: 750
17 : 79590: 83950: 720
Checking ROM Copy
Check sum Value ........................... 639E
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 5000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 506.
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
Checking RZTbl
Error ..................................... UBA 9 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
Checking P-List
Error ..................................... UBA 44 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/44
Checking G-List
Checking RZTbl-PList
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 323
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP* "
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking [DISK/PW]
Error ..................................... Wrong Module Id "93"
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 ................................. UBA 44 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/44
Module 19 ................................. Ok
Module 1A ................................. Ok
Module 1B ................................. Ok
Module 1C ................................. Ok
Module 1D ................................. UBA 704 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/165
Module 1E ................................. Ok
Module 1F ................................. UBA 8 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
Module 20 ................................. Ok
Module 21 ................................. Ok
Module 22 ................................. Ok
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F ................................. Ok
Module 30 ................................. Ok
Module 32 ................................. Ok
Module 33 ................................. Ok
Module 34 ................................. UBA 447 Reading error : Maxtor techno command error. Command : 53. Code : 0016 C/H/S : 352/3/448
Module 37 ................................. Ok
Module 38 ................................. Ok
Module 39 ................................. Ok
Module 41 ................................. Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 ................................. Ok
Module 45 ................................. Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 ................................. UBA 703 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/165
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F ................................. Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E ................................. UBA 758 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/219
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 ................................. Ok
Module 64 ................................. Ok
Module 65 ................................. Ok
Module 66 ................................. Ok
Module 67 ................................. Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 70 ................................. Ok
Module 71 ................................. Ok
Module 72 ................................. Ok
Module 73 ................................. Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 ................................. UBA 9 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
Module 79 ................................. Ok
Module 7A ................................. Ok
Module 7B ................................. Ok
Module 7C ................................. Ok
Module 7D ................................. Ok
Module 7E ................................. Ok
Module 7F ................................. Ok
Module 80 ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 92 ................................. Ok
Module 94 ................................. Ok
Module 95 ................................. Ok
Module 96 ................................. Ok
Module 97 ................................. Ok
Module 98 ................................. Ok
Module 99 ................................. Ok
Module 9A ................................. Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E ................................. Ok
Module 9F ................................. Ok
Module A0 ................................. Ok
Module A2 ................................. Ok
Module A3 ................................. Ok
Module A4 ................................. Ok
Module A5 ................................. Ok
Module A6 ................................. Ok
Module 1B ................................. UBA 706 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/167
Module 34 ................................. UBA 447 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/448
SA surface verification
Zone Id ................................... 1
Start UBA ............................ 8
Size ................................. 1 200
8 ......................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
9 ......................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
10 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/10
11 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/12
12 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/12
13 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/15
14 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/15
15 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/15
27 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/29
28 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/29
29 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/29
32 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/33
33 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/33
42 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/44
43 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/44
44 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/44
45 ........................................ Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/45
446 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/448
447 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/448
448 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/448
703 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/165
704 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/165
705 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/165
757 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/219
758 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/219
759 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/219
771 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/233
772 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/233
773 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/233
774 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/234
775 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/235
776 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/236
777 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/237
Errors .................................... 33
Zone Id ................................... 2
Start UBA ............................ 1 208
Size ................................. 4 416
Errors .................................... 0
Zone Id ................................... 3
Start UBA ............................ 11 624
Size ................................. 3 300
Zone Id ................................... 4
Start UBA ............................ 14 924
Size ................................. 2 900
Zone Id ................................... 5
Start UBA ............................ 17 824
Size ................................. 400
Zone Id ................................... 6
Start UBA ............................ 5 624
Size ................................. 6 000
Zone Id ................................... 7
Start UBA ............................ 18 630
18 630 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/271
18 631 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/271
18 640 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/281
18 641 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/281
18 642 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/284
18 643 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/284
18 644 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/284
18 661 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/303
18 662 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/303
18 663 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/303
18 664 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/306
18 665 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/306
18 666 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/306
19 506 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/68
19 507 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/68
Errors .................................... 15
Zone Id ................................... 8
Start UBA ............................ 19 830
Zone Id ................................... 9
Start UBA ............................ 0
Size ................................. 8
7 ......................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/9
Zone Id ................................... 10
Start UBA ............................ 32 367
32 373 .................................... Maxtor techno command error. Command : 53. Code : 9280
32 374 .................................... Maxtor techno command error. Command : 53. Code : 9280
Errors .................................... 2
Zone Id ................................... 11
706 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/167
707 ....................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 353/3/167
Zone Id ................................... 12
Zone Id ................................... 13
Zone Id ................................... 14
Zone Id ................................... 15
Zone Id ................................... 16
Zone Id ................................... 17
19 508 .................................... Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 388/3/68
Errors .................................... 14
Zone Id ................................... 18
Zone Id ................................... 19
Zone Id ................................... 20
Test completed
Read G-List
Module Id : AT_POL 0
Realloc area LBA : 80293334
Read P-List
RZTbl
PostPosted: April 25th, 2008, 7:30
Without Plist you can't recover.
Have you tried to read it with 'ignore errors'.
Mostly the beginning of the plist is good and there are errors to the end, but mostly only beginning of the module is filled with data. Then you could correct the bad sectors by hand.
Then i would advise hotswap. Seems to me the only method.
Best regards,
Dobre
Murphy was an optimist
PostPosted: April 25th, 2008, 7:44
Hi Dobre
Thank you very much for your help. I could read p list without errors. In ISA i get these 3 modules bad
02C00002
00090020
00290139
Is it Safe (for data) to rewrite these modules?
Thanks & regards
Hddbug
PostPosted: April 25th, 2008, 8:28
Can you tell me what modules these stand for ? 0009 is zone table, other modules are ... ?
Dobre
PostPosted: April 25th, 2008, 8:36
from manual:
Translator regeneration:
The feature allows the users to rebuild translator modules PN=18h, PN=37h,PN=78h based on the data found in defect list from the module PN=33h.Regeneration process clears the translator adding the defects from that list one by one using the techno command for defects assignment. There is an important peculiarity: if a drive had tracks hidden on the RZTBL level,they will be shifted to P-List level. That may cause modification in the interpretation of defects by the drive ( hard to explain so far). No shift of user data occurs in that case.
Hope this helps.
PostPosted: April 25th, 2008, 9:17
Ok, thanks.
So if it are the translator modules that are damaged, that is not a big problem.
Follow the manual for hotswap. Copy all important modules to the donor, regenerate translator, put the drive in standby and change the pcb. You should then be able to access the data on the patient drive.
Dobre
PostPosted: April 25th, 2008, 12:33
Hi Dobre , trubarevacki
Thanks for your valuable help. I tried to check SA structure with option Reassign Bad sectors. Process went smoothly
Now when i check modules , All modules are Ok except Rztbl. Using ISA i have created loader .
Despite so much work Drive only changes from firmware 6159z to 61590 with correct capacity but without Serial firmware loaded from database other wise i get error & utility does not start . DE didn't worked as well.
finally I cleared Glist & regenerated Translator & now i can go into utility without loading firmware from database. Please let me know if ihave done somthing wrong.
Thanks & Regards
hddbug
PostPosted: April 28th, 2008, 3:47
Hi Hddbug,
If that worked ok then all should be fine. You should be able now to access your data and copy it from the drive with DE.
Dobre
Users browsing this forum: Google [Bot], Hardcore Games and 54 guests
