 Post subject: Samsung MP0804H power on and then off
PostPosted: April 16th, 2008, 1:13
I have Samsung MP0804H, Rev B, power on and then off by itself, not calibrated.
I change PCB and ROM same problem, successfully change HDA and same problem.
Hot swap it works and all modules are ok but unable to get the data using DE.
checked SA, service tracks all ok. Once i power it off and on again the problem persist.
Any ideas what is going on guys? Thank you.
 Post subject: Re: Samsung MP0804H power on and then off
PostPosted: April 16th, 2008, 10:48
a terminal report could give some hint.
PostPosted: April 16th, 2008, 22:44
Hi Pepe
This is what i get from terminal:
IndS=+00001
Spn OK
H: +00000
Load
SK C: 00000C26
ENG>SRV> AP_EST
C: 000001F4 H: +00000
SK C: 00005100
SvoTbl Loaded
AP_FSAM
SK C: 00000B3F
BD
SCyl: +0000008211 TCyl: +0000003069
KD
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B
LED 5B = Maintenance Read Error {"what does it means?"}
Thank you
PostPosted: April 19th, 2008, 11:59
anyone pls?
PostPosted: April 19th, 2008, 23:14
Hello friend
Its like SA problems check u PM
Best Regards
Alberto
PostPosted: May 3rd, 2008, 23:35
As suggested, i copied modules SLISTHDR,SLIST,TLIST,ALIST,CONFIG,GEO_TBL and MRTUNEMT from patient to donor and performed hot swap. I still could not access the data although the patient's modules all are ok.
Any ideas guys? thank you.
Users browsing this forum: No registered users and 73 guests
