 Post subject: Maxtor 6E040L0510 module 18 error
PostPosted: May 9th, 2008, 2:33
Hi guys
Need help on Maxtor 6E040L0510, it has module 18 (UBA 41) error, this module is unique to this drive and crucial for data access, can i run regenerate translator? or rewrite module 18 with the same model Maxtor 6E040L0510614, KMCA, B8FEA.?
Thank you for any help.
 Post subject: Re: Maxtor 6E040L0510 module 18 error
PostPosted: May 9th, 2008, 10:11
I think it will be safe to regenerate translator..
hard-disk-drives-repair-and-data-recovery-f1/n40p-firmware-t8900.html
PostPosted: May 9th, 2008, 22:22
thank you so much for taking time in replying trubarevacki , i will try.
PostPosted: May 9th, 2008, 23:12
I tried regenerate translator it didnt work , drive become "not ready".
Here's the errors:
SA structure test
Selected family ........................... N40P
Model ..................................... Maxtor 6E040L0
Firmware .................................. NAR61590
Serial .................................... E1AJHBQE
Min. cylinder ............................. 0
Max. cylinder ............................. 4294967295
Checking UList
Id ........................................ 37
Read ...................................... Yes
Header .................................... U_LIST00
Checksum .................................. Ok
The number of SA defects .................. No
P-List size ............................... 8
HDD configuration module
Id ........................................ 1F
Header .................................... DISK
Checksum .................................. Error
Serial number ............................. E1AJHBQE
Max LBA ................................... 80293248
Head number ............................... 1
Head map .................................. 3
SA head map ............................... 3
Model1 ............................... Maxtor 6E040L1
Max LBA .............................. 80293248
Model2 ............................... Maxtor 6E020L1
Max LBA .............................. 40718160
Model3 ............................... Maxtor 6E030L1
Max LBA .............................. 60058656
Model4 ............................... Maxtor 6E020L1
Checking Calibration adaptives
Id ........................................ 1E
Header .................................... SRV6À]
Checking User data adaptives
Header .................................... CR0TF`
Checking Zone Table
# : Start Cyl: End Cyl: SPT
1 : 352: 411: 540
2 : 412: 5278: 1140
3 : 5279: 11018: 1125
4 : 11019: 16642: 1105
5 : 16643: 29027: 1080
6 : 29028: 34922: 1044
7 : 34923: 40236: 1020
8 : 40237: 46449: 990
9 : 46450: 51301: 960
10 : 51302: 54738: 936
11 : 54739: 61793: 900
12 : 61794: 65428: 864
13 : 65429: 68486: 840
14 : 68487: 72980: 810
15 : 72981: 76346: 780
16 : 76347: 79589: 750
17 : 79590: 83950: 720
Checking DMCS
Id ........................................ 1D
Header .................................... Ok
HUTL Start UBA ............................ 5624
HUTL Rec Count ............................ 0
HUTL Length ............................... 32
HUSR Start UBA ............................ 5656
USR Rec Count ............................. 694
HUSR Blk Count ............................ 2
HUSR Total Sectors ........................ 32
HUST Blk Len .............................. 16
Checking ROM Copy
Check sum Value ........................... 4265
Checking ATA overlays
Header1 ................................... MO
Header2 ................................... 5000
OverlayId ................................. 0003
ROM CRC ................................... Ok
OverlayId ................................. 0004
OverlayId ................................. 0005
OverlayId ................................. 0006
OverlayId ................................. 0007
Checking Techno mode overlays
Header2 ................................... 50b.
OverlayId ................................. 0008
OverlayId ................................. 0009
OverlayId ................................. 000A
OverlayId ................................. 000B
OverlayId ................................. 000C
OverlayId ................................. 000D
OverlayId ................................. 000E
OverlayId ................................. 000F
OverlayId ................................. 0010
OverlayId ................................. 0011
OverlayId ................................. 0012
OverlayId ................................. 0013
OverlayId ................................. 0014
OverlayId ................................. 0015
OverlayId ................................. 0016
OverlayId ................................. 0017
OverlayId ................................. 0018
OverlayId ................................. 0019
OverlayId ................................. 001A
OverlayId ................................. 001B
OverlayId ................................. 001C
OverlayId ................................. 001D
OverlayId ................................. 001E
OverlayId ................................. 001F
Checking RZTbl
Checking P-List
Error ..................................... UBA 164 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/166
Checking G-List
Checking RZTbl-PList
Checking HLists
Block0
Header .................................... UHRS0000
Defect Count .............................. 637
Block1
Header .................................... UHRS0010
Defect Count .............................. 57
Checking security
Header .................................... SECU
User Password ............................. "********************************"
Master Password ........................... "Maxtor*INIT SECURITY TEST STEP* "
User password setup ....................... No
Master code ............................... FFFE
Security level ............................ HIGH
Checking S.M.A.R.T.
[SMRT_T] .................................. Ok
[SMRT_A] .................................. Ok
[SMRT_AC] ................................. Ok
[SMART_SUMMAR] ............................ Ok
[SMART_ST] ................................ Ok
[SMART_HOSTV] ............................. Ok
Checking [DISK/PW]
Error ..................................... Wrong Module Id "93"
Checking All
Module 00 ................................. Ok
Module 01 ................................. Ok
Module 03 ................................. Ok
Module 04 ................................. Ok
Module 05 ................................. Ok
Module 08 ................................. Ok
Module 09 ................................. Ok
Module 0A ................................. Ok
Module 0B ................................. Ok
Module 0C ................................. Ok
Module 0D ................................. Ok
Module 0E ................................. Ok
Module 0F ................................. Ok
Module 10 ................................. Ok
Module 11 ................................. Ok
Module 12 ................................. Ok
Module 13 ................................. Ok
Module 14 ................................. Ok
Module 16 ................................. Ok
Module 18 Copy0 ........................... UBA 185 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 352/3/187
Module 18 Copy1 ........................... UBA 18786 Reading error : Maxtor techno command error. Command : 53. Code : 0111 C/H/S : 386/3/428
Module 19 Copy0 ........................... Ok
Module 19 Copy1 ........................... Ok
Module 1A Copy0 ........................... Ok
Module 1A Copy1 ........................... Ok
Module 1B Copy0 ........................... Ok
Module 1B Copy1 ........................... Ok
Module 1C Copy0 ........................... Ok
Module 1C Copy1 ........................... Ok
Module 1D Copy0 ........................... Ok
Module 1D Copy1 ........................... Ok
Module 1E Copy0 ........................... Ok
Module 1E Copy1 ........................... Ok
Module 1F Copy0 ........................... Ok
Module 1F Copy1 ........................... Ok
Module 20 Copy0 ........................... Ok
Module 20 Copy1 ........................... Ok
Module 21 Copy0 ........................... Ok
Module 21 Copy1 ........................... Ok
Module 22 Copy0 ........................... Ok
Module 22 Copy1 ........................... Ok
Module 24 ................................. Ok
Module 27 ................................. Ok
Module 28 ................................. Ok
Module 29 ................................. Ok
Module 2A ................................. Ok
Module 2B ................................. Ok
Module 2D ................................. Ok
Module 2F Copy0 ........................... Ok
Module 2F Copy1 ........................... Ok
Module 30 Copy0 ........................... Ok
Module 30 Copy1 ........................... Ok
Module 32 Copy0 ........................... Ok
Module 32 Copy1 ........................... Ok
Module 33 ................................. Ok
Module 34 Copy0 ........................... Ok
Module 34 Copy1 ........................... Ok
Module 37 Copy0 ........................... Ok
Module 37 Copy1 ........................... Ok
Module 38 Copy0 ........................... Ok
Module 38 Copy1 ........................... Ok
Module 39 Copy0 ........................... Ok
Module 39 Copy1 ........................... Ok
Module 41 Copy0 ........................... Ok
Module 41 Copy1 ........................... Ok
Module 42 ................................. Ok
Module 43 ................................. Ok
Module 44 Copy0 ........................... Ok
Module 44 Copy1 ........................... Ok
Module 45 Copy0 ........................... Ok
Module 45 Copy1 ........................... Ok
Module 46 ................................. Ok
Module 47 ................................. Ok
Module 48 Copy0 ........................... Ok
Module 48 Copy1 ........................... Ok
Module 49 ................................. Ok
Module 4A ................................. Ok
Module 4B ................................. Ok
Module 4C ................................. Ok
Module 4D ................................. Ok
Module 4E ................................. Ok
Module 4F Copy0 ........................... Ok
Module 4F Copy1 ........................... Ok
Module 54 ................................. Ok
Module 55 ................................. Ok
Module 56 ................................. Ok
Module 57 ................................. Ok
Module 58 ................................. Ok
Module 59 ................................. Ok
Module 5A ................................. Ok
Module 5B ................................. Ok
Module 5C ................................. Ok
Module 5D ................................. Ok
Module 5E Copy0 ........................... Ok
Module 5E Copy1 ........................... Ok
Module 5F ................................. Ok
Module 60 ................................. Ok
Module 61 ................................. Ok
Module 62 ................................. Ok
Module 63 Copy0 ........................... Ok
Module 63 Copy1 ........................... Ok
Module 64 Copy0 ........................... Ok
Module 64 Copy1 ........................... Ok
Module 65 Copy0 ........................... Ok
Module 65 Copy1 ........................... Ok
Module 66 Copy0 ........................... Ok
Module 66 Copy1 ........................... Ok
Module 67 Copy0 ........................... Ok
Module 67 Copy1 ........................... Ok
Module 68 ................................. Ok
Module 69 ................................. Ok
Module 6A ................................. Ok
Module 6B ................................. Ok
Module 70 Copy0 ........................... Ok
Module 70 Copy1 ........................... Ok
Module 71 Copy0 ........................... Ok
Module 71 Copy1 ........................... Ok
Module 72 Copy0 ........................... Ok
Module 72 Copy1 ........................... Ok
Module 73 Copy0 ........................... Ok
Module 73 Copy1 ........................... Ok
Module 74 ................................. Ok
Module 75 ................................. Ok
Module 76 ................................. Ok
Module 77 ................................. Ok
Module 78 Copy0 ........................... Ok
Module 78 Copy1 ........................... Ok
Module 79 ................................. Ok
Module 7A Copy0 ........................... Ok
Module 7A Copy1 ........................... Ok
Module 7B Copy0 ........................... Ok
Module 7B Copy1 ........................... Ok
Module 7C ................................. Ok
Module 7D ................................. Ok
Module 7E ................................. Ok
Module 7F ................................. Ok
Module 80 ................................. Ok
Module 81 ................................. Ok
Module 82 ................................. Ok
Module 83 ................................. Ok
Module 84 ................................. Ok
Module 85 ................................. Ok
Module 86 ................................. Ok
Module 87 ................................. Ok
Module 88 ................................. Ok
Module 89 ................................. Ok
Module 8A ................................. Ok
Module 8B ................................. Ok
Module 8D ................................. Ok
Module 8E ................................. Ok
Module 8F ................................. Ok
Module 92 ................................. Ok
Module 94 Copy0 ........................... Ok
Module 94 Copy1 ........................... Ok
Module 95 Copy0 ........................... Ok
Module 95 Copy1 ........................... Ok
Module 96 Copy0 ........................... Ok
Module 96 Copy1 ........................... Ok
Module 97 Copy0 ........................... Ok
Module 97 Copy1 ........................... Ok
Module 98 Copy0 ........................... Ok
Module 98 Copy1 ........................... Ok
Module 99 Copy0 ........................... Ok
Module 99 Copy1 ........................... Ok
Module 9A Copy0 ........................... Ok
Module 9A Copy1 ........................... Ok
Module 9B ................................. Ok
Module 9C ................................. Ok
Module 9D ................................. Ok
Module 9E Copy0 ........................... Ok
Module 9E Copy1 ........................... Ok
Module 9F ................................. Ok
Module A0 ................................. Ok
Module A2 ................................. Ok
Module A3 ................................. Ok
Module A4 ................................. Ok
Module A5 Copy0 ........................... Ok
Module A5 Copy1 ........................... Ok
Module A6 Copy0 ........................... Ok
Module A6 Copy1 ........................... Ok
Module A8 ................................. Ok
Module AB ................................. Ok
Module AC ................................. Ok
Module AD ................................. Ok
Module FF Copy0 ........................... Ok
Module FF Copy1 ........................... Ok
PostPosted: May 10th, 2008, 5:04
You have to fix DISK module first...
PostPosted: May 10th, 2008, 11:20
Module 18 on this model is a P-List.
You won't be able to regenarate translator without it.
Do you need data from that drive or you want to fix it?
Where was that drive manufactured?
www.datarecoveryne.com
PostPosted: May 10th, 2008, 21:23
hi harddrivespecialist data is needed, manufactured in Singapore.
trubarevacki , Thanks i will try
PostPosted: May 10th, 2008, 23:36
Hi thanks for replying all.
I could switch the drive to ALT-SA, can i copy P-list (module 18 from ALT-SA to the faulty module?)
Thank you
PostPosted: May 14th, 2008, 5:45
Have you tried reassigning BAD sectors with SA surface Verication?
Users browsing this forum: Google [Bot] and 77 guests
