 Post subject: Somebody HELP me!!!!
PostPosted: May 15th, 2008, 6:56
My hdd (Maxtor 40gb) can't be detected in bios. berfore that, i format using hdd low level format tool from hddguru. but before it finished, i cancelled it. later it can't be detected!! Someone who can fix this hdd help me please!!!!
 Post subject: Re: Somebody HELP me!!!!
PostPosted: May 15th, 2008, 7:03
hdd model ?
Spasavanje podataka
PostPosted: May 15th, 2008, 9:32
IDE...
PostPosted: May 15th, 2008, 10:54
Hi, well it seems the data is not very important here, so I suggest not to bother yourself about this drive, get a new one and go on!
IDE is not a HDD model BTW...
PostPosted: May 17th, 2008, 5:35
WOW, the Data is very important, it's my father's company data. :lol: :lol:
PostPosted: May 17th, 2008, 5:37
oh.... my hdd model is maxtor 4D040H2, i hope that after repair it can be used again!! Help Me PLEASE!!! :( :( :( :( :( :( :(
PostPosted: May 17th, 2008, 6:17
FORMAT=erase all data...means your father's company data is gone....so you should take pepe's advice and go by a new one.
Rgds
www.datasave.ro
PostPosted: May 17th, 2008, 8:36
Dear RoughNecks,
Plz do not in a panic!
Format doesn't mean that your data can not be recovered, plz contact SalvationDATA, we can help you easily find back the data.
Best wishes
Selina
Another professional spammer from SalvationData. Links removed.
Email/MSN: selina ATsalvationdata.com
data recovery software and Flash recovery solution
PostPosted: May 17th, 2008, 9:40
If your data is so important why did you format the hard drive?
Not only that but why did you use the low level format utility?
If your data is really important I would suggest you give the job to a professional recovery technician. That way you won't do any more damage.
Even now it might be too late, I havn't used that format utility but some I know will overwrite every sector on the drive.
PostPosted: May 17th, 2008, 11:31
U gave the data the big shot with the LLF tool, I am really surprised why u used it on your father's company data...
If somebody manages to make the drive readable, the chances of a successful recovery are really faint, at least depending on how many percents were done by LLF.
I think U shouldn't mess with the drive anymore, but gave it to a pro.
PostPosted: May 17th, 2008, 14:58
Low Level Format writes zero to every sector. So, its impossible to recovery data from the HDD. But, as you stopped the LLF, there have chance to recover data, it depends how many sector was zero filled.
Can you indicate how many sector or how much percentage did u format using LLF?
It is better to send your HDD to Professional providing your LLF job done (how more) by you.
N.B: Low level formatted sectors data could not be recovered ever.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: May 19th, 2008, 6:56
Hmm...... it's about finished. BTW, i have backup the data, sorry. :oops: :oops:
But now i hope that the HDD can be used again. Any idea??
PostPosted: May 19th, 2008, 7:04
BTW, i read from another forum, they wrote that fix HDD mobo maybe can fix the HDD, what do you think?
If i upgrade it firmware can be fixed?
PostPosted: May 19th, 2008, 16:03
Dear,
Dont make confused us. We are trying to help you. Always deal with real and exact information what you deal. I hope you understand what I mean.
Here all are helpful, but when you try to make confused all then you should not hope any help ever.
__________
THANK YOU
SHAHI
PostPosted: May 20th, 2008, 0:57
Sorry, i don't mean to confuse u all. Now i just want my HDD can be used again......
PostPosted: May 20th, 2008, 1:56
Do you really want to spend hundreds of dollars in tools to repair an old 40GB drive? Just buy a new drive. Consider yourself incredibly lucky you have a backup. Consider it a cheap lesson.
PostPosted: May 20th, 2008, 10:18
Meaning?? If i want my hdd can be used i must have to buy a tool?? Software? Other ways?
PostPosted: May 20th, 2008, 13:13
Based on what you've said, it's probably corrupted firmware. The cheapest tool that can fix that is Salvation, around $400. Frankly, a 40Gb drive isn't even worth the effort of thinking about it.
However, you do seem determined. Laura at Salvation Data will be happy to sell you what you need. No guarantee the tool will fix the drive tho.
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 53 guests
