 Post subject: Damaged ROM in Hitachi PLAT drive
PostPosted: May 15th, 2008, 11:14
Hi everybody,
I received this HDS728040PLAT20 drive. Faulty board. External ROM chip exploded too. This board has both NVRAM and ROM chips.
I was not able to find a spare card. First line on original one is 0A30417. I have all cards with 0A30418.
NVRAM is good. Tried to reprogram card with 0A30418, no success to access modules.
So, no exact match in spare. No original ROM... How to build a good compatible card ?
Thanks in advance,
Max
 Post subject: Re: Damaged ROM in Hitachi PLAT drive
PostPosted: May 15th, 2008, 17:20
tell us the NVRAM version to find a matching ROM image U can program onto the donor board.
PostPosted: May 16th, 2008, 4:50
Thanks for the quick reply. Here the NVRAM.
Thanks again
Max
File comment: PLAT NVRAM
PLAT NV-RAM.zip [845 Bytes]
Downloaded 348 times
PostPosted: May 16th, 2008, 8:58
Sorry, I could not find a ROM image for this version.
PostPosted: May 16th, 2008, 10:13
Here it is
ROM.zip [40.54 KiB]
Downloaded 315 times
PostPosted: May 16th, 2008, 10:17
You need to use PCB with both chips
If you just solder ROM chip on PCB which previously didn't have one - it will not work
Don't forget to match CPU
PostPosted: May 19th, 2008, 3:50
Thanks Sirs. I'm going to try...
Users browsing this forum: No registered users and 90 guests
