 Post subject: problem with Toshiba MK1032GAX, slow transfer
PostPosted: May 19th, 2008, 8:34
Hello. I have some problem with my HDD Toshiba MK1032GAX. Last days the transfer quickly slowed down. Smart data looks fine (every parameters are O.K.), The disk is used with external HDD aluminium rack.
Here is the test from HDDtune:http://telbox.hit.bg/temp/TOSHIBA_MK1032GAX_BAD.png
The disk is not dropped. What could be the reason for these strange slow downs.thanks in advance!
 Post subject: Re: problem with Toshiba MK1032GAX, slow transfer
PostPosted: May 19th, 2008, 8:38
Hi Tracker,
I fear the heads are starting to fail.
I would backup the data on the disk asap before the disk dies completely.
Best regards,
Dobre
Murphy was an optimist
PostPosted: May 19th, 2008, 9:43
My guess is that the motor is dragging due to fluid bearing failure.
Toshibas are the easiest for head / platter swaps.
Jon
http://www.datasaversllc.com
PostPosted: May 19th, 2008, 9:48
Yep, is also a possibility.
Dobre
Users browsing this forum: No registered users and 86 guests
