 Post subject: Looking for a solution to disk failure!
PostPosted: May 16th, 2008, 1:57
Hi people, I have been using my disk for quite a long time but the other day I heard the drive making some noise and had to restart the system again. But when I did that the disk would not boot and I fear that the data might be deleted or lost. So, if you people have any know about the ways to get this done right or if you can at least suggest me the ways to handle this …it will be a great help.
 Post subject: Re: Looking for a solution to disk failure!
PostPosted: May 16th, 2008, 2:20
Well, I don't know much about those hard drive thingies, but I heard someone once put one in a freezer...
Seriously, if the data is very important to you, you need to send it to a professional. That's the right way to do it.
PostPosted: May 16th, 2008, 16:55
A freezer will draw moisture from the air and crystalize on the circuit board. After you take it out of the freezer this moisture will thaw out and short out the electronics. Use at your own risk.
PostPosted: May 16th, 2008, 23:03
This seems to be a genuine problem. It must be probably due to the “noise” you have stated….there may be some bad sectors in the boot sector or may be the OS has been corrupted. These are all just views but you can’t be sure…..you must try to recover data disk (link to diskemergency.com removed by moderator) and make it as simple as possible to avoid complications. There are many ways to get that done and I hope that you get your data back from suitable ways.
Added by moderator: Let's welcome another bunch of idiots who feel that they can shit in these forums with their spam: diskemergency.com
PostPosted: May 16th, 2008, 23:05
Just to make it clear, I wasn't advocating anyone actually put a drive in the freezer. I was just in another mood :)
PostPosted: May 16th, 2008, 23:13
While simpler is often more reliable, Data Recovery is usually nowhere near simple. Taking the wrong actions can make an easy job difficult, or impossible. Try smart over simple. Know when you are in over your head. If it's important, send it to a pro.
PostPosted: May 17th, 2008, 3:46
Rchadwick,
I'm starting to know your moods :lol:
It is best to have some humour in our job, although a beginner will not always know when we are not serious.
Tell them to open up the drive and use a vacuumcleaner to remove the dust and some will do it for sure. :)
Cheers,
Dobre
Murphy was an optimist
PostPosted: May 17th, 2008, 8:43
Dear wilson,
It seems that yourhard disk has bad sectors or firmware corruption. To soleve this problem, plz contact SalvationDATA(a professional data recovery solution company ).
Best wishes!
Selina
Another professional spammer from SalvationData. Links removed.
Email/MSN: selina ATsalvationdata.com
data recovery software and Flash recovery solution
PostPosted: May 17th, 2008, 12:01
using professional data recover equipment requires good experience and knowledge of hdd , its better u goto a pro rather then buying any tool .
PostPosted: May 21st, 2008, 4:19
Dear Sir,
May I know your disk model number and more details ?
Did you try some free software like HDDSCAN to diagnose it? It seems your disk has a head crash.
More details will help us to offer more useful advice.
Best Regards
Laura
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: May 22nd, 2008, 5:36
if the hdd is still detected, try to image the hdd to a new hdd sector by sector. If ususual sound occurs, stop the hdd using immediately and send it to professional. otherwise data will loss more, might be unrecoverable if platter causes scratch.
You know the worth of your data, so take quick decision.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
Users browsing this forum: Google [Bot] and 74 guests
