 Post subject: Help with Fujitsu MHV2080BH
PostPosted: May 27th, 2008, 5:00
Hi everyone!
I need help with trying to fix a Fujitsu MHV2080BH PART NO.CA06672-B3400AP
with REV NO. A2 and Firmware number OFFCEA-0081002D from a MacBook.
The drive makes clicking sound due to the fact that the heads go back and
fourth without stopping. How should I proceed ?? The disk is undetectable from
the bios, can I upgrade the firmware somehow or should I replace the PCB and
if so how do I match the donor drive
Thanks in advance!
 Post subject: Re: Help with Fujitsu MHV2080BH
PostPosted: May 27th, 2008, 5:30
Kirioulis,
These symptoms indicate most probaly defective heads.
To get the data, heads should be replaced; this is work for a pro in a cleanroom.
Best regards,
Dobre
Murphy was an optimist
PostPosted: May 27th, 2008, 7:41
So u think there is nothing to be gained by replacing
the pcb huh?
Thanks for your reply!!!
PostPosted: May 27th, 2008, 7:50
No, chances are very high that changing the PCB will not give you any help.
Dobre
Users browsing this forum: No registered users and 82 guests
