 Post subject: WD2000BB-00DAA0 will not sleep
PostPosted: May 30th, 2008, 16:34
Hi Gurus,
I'm trying to do a hotswap with this drive for a dead drive(stays busy) and I cannot get it to go into standy mode. When I send the standby command, I get ERR and ABR status registers lit. Not sure if this helps, but when I load the drive up, I get: "Device Error Detected - 59/01 (AMN)". Also, a few of the B modules show errors, but I cannot repair them as both copies are bad.
I've tried sleep mode in both PC3000 and Salvation Data.
Does this sound like a module problem?
Thanks for your help!
A
 Post subject: Re: WD2000BB-00DAA0 will not sleep
PostPosted: May 31st, 2008, 10:24
Hello acforensinc?
wich was the problem on first before did hot swap ? Knocks, lost readiness? reach DRDY DSC?, BSY? and u donnor did u check if u donnor has same FW version and head map?
Best Regards
Users browsing this forum: No registered users and 72 guests
