 Post subject: Can anyone help? Question about Seagate HD
PostPosted: June 2nd, 2008, 13:54
I damaged one inductor on the PCB of Seagate ST3320620AS
The inductor is written as 3R3
I want to replace that SMD
But I am not sure that if I can use TDK VLCF5020T-3R3N1R6 to replace it
Here is the data sheet of TDK power inductor
http://www.tdk.de/company/inductors_coi ... cf5020.pdf
and here is the pix of my seagate harddisk pcb
The damaged part is inside the red circle
http://us.f6.yahoofs.com/hkblog/rZbsucqeBRmvtMy0i78iu44Dmg--_1/blog/20080531113638971.jpg.jpg?ib_____DWYHCLZiH
Any expert can help me out? Thanks
 Post subject: Re: Can anyone help? Question about Seagate HD
PostPosted: June 5th, 2008, 10:05
Most likely (99%) you can use it.
Dmitry
PostPosted: June 6th, 2008, 10:43
Thank you for your reply.
I will go get it.
PostPosted: June 6th, 2008, 14:32
Hi ,
Try a Direct Shorting of The Same also ,It Will Not Spoil the PCB for Sure ,See If It works till Replacement Comes
PostPosted: June 6th, 2008, 17:48
Hi Amarbir,
These things are parts of DC-DC converters running at some hundred KHz. At this frequency these have some reasonable impedance that your short won't have -> it will overload the driving circuit.
PostPosted: June 7th, 2008, 0:44
pepe wrote:
Hi Amarbir,
Pepe ,
True ......But What He Could Try Is a Inductor or the Same Value From Other Bad HDD's
PostPosted: June 7th, 2008, 3:06
Amarbir, they would have not fitted an inductor if could be shorted... It's part of the circuit. A smps with one or more coils short in the primary typically break the switching or trigger the protection (basic engineering of smps or dc-dc converter circuits!) sorry could not resist posting, despite I quit definitively dr and related stuff - at last! . Regards
PostPosted: June 10th, 2008, 14:47
True ,
Thats What i Said ,and Do Not Worry We Will Get You Back In DR BL :vo:
