 Post subject: Experiment
PostPosted: June 3rd, 2008, 0:45
Hello ,
I have done selfscan on 50 seagate ALPINE drive 40 of them were successfull but in the remaining 10 drives selfscan stopped at a point and in some i completed successfully but after restart the drive showed :
Error reading reserved track defect list .
What part of the firmware should i write to fix this problem ?
I have backed up APP code , cert code , cert table and Overlay before selfscan .
Thanks in advance .
 Post subject: Re: Experiment
PostPosted: June 3rd, 2008, 4:34
Hi rameez
If the head(s) are ok , hot swap with an identical drive(same fw at least) helped me to resolve this problem.....but only if the heads are ok....
Rgds
www.datasave.ro
PostPosted: June 3rd, 2008, 12:56
i need to repair the hdd should i use hot swap ?
PostPosted: June 4th, 2008, 4:15
Of course. Hot swap option is only for repairing....after hot swap u need to play with adaptives and other options. So if u need the data u got to use another solution. Btw did u try using loader from pc3k pci?...
Rgds
www.datasave.ro
PostPosted: June 6th, 2008, 3:34
Yes i tried loading the loader but the drive wont accept it . I will try hot swap and let u know the results .
