 Post subject: Seagate Tonka 2 160 GB problems
PostPosted: June 4th, 2008, 12:43
Hello friends & hddguru´s
Now get another strange case, Seagate 160Gb one platter two heads, on first the hdd was opened before and the people who tried "recover" damaged the MR Sensors from Heads :? , and on the platter looks, like little scratch caused by a dropped , of "screws", its not many damaged but are , like 4 little scratch´s over platter, and a head crash on the land zone, well, we got donnor, and did head swap, after that the hdd send´s
ATA Registers: BSY DSC
Interface task reset
1024k x 16 SDRAM
TONKA2 - 1_Disk M-31 12-07-05 09:13
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
(P)PATA Reset
DiskAccess ReadSector EC=47 at ffffffff.00.0002
DiskAccess ReadSector EC=43 at ffffffff.01.0002
12
Initializing SMART SectorsDiskAccess ReadSector EC=43 at ffffffff.00.0001
Read Ver Retrys
DiskAccess ReadSector EC=47 at ffffffff.00.0001
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Failed sys sect. write
DiskAccess ReadSector EC=47 at ffffffff.01.0002
DiskAccess ReadSector EC=47 at ffffffff.00.0080
DiskAccess ReadSector EC=43 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>
But with command "." u got Ready LBA xxxxx and Age 50.. after tried and tried the hdd some times reach´s DRDY DSC, not knocks, i tried to clone it only was possible to get like 10% , of sectors and lost readiness, and made sounds like head touch platters, well i tried to get the most important folders, but only a few of them, after that, the hdd lost readiness, strange to reach readiness again, i should connect the hdd without jumper, and plug on the terminal connector, and after that was reaching readiness, and get some files, but not all, now its impossible to reach readiness, but the strange we returned heads to donnor HDA, and the Donnor works , fine, even read SA, so its looks like a SA problem, im thinking on wrote ATA Overlay, from Donnor and wrote on patient,
What do u think
Thanks again
Sinceraly
Alberto
Update 040708
Now i tried some tests and this was the results
After that i tried to erase smart and g list.,
T>Eng Rev = .0B5
TONKA2 - 1_Disk 3.AAE 12-07-05 09:16 AAE,1D_P_013_N0,4T
CERT Rev = .08G
NONE
Mask Rom Rev = M-31
Unique Descriptor = .3N0
T>
F>R4
Spin Ready
F>Pgm=00 Trk=000155C0(000155C0[016FD3]).0(0).238(FFFF) Zn=FF Err=00 ErCt=0000 Hlth=0000 CHlth=0000 Ready LBA=00000000
F>
:000000010000 AX' ' " "000155AA-000156D7
F>
e c r = 0 0 1
F>
F>/1
F>Interface task reset
1024k x 16 SDRAM
Spin Ready
(P)PATA Reset
12FFLUSH-1 Fail <------ Defect list Full???
CE Log ErrCode=0 LBA=0 Type=aDiskAccess ReadSector EC=43 at ffffffff.00.0059
DiskAccess ReadSector EC=47 at ffffffff.01.0059
DiskAccess ReadSector EC=43 at ffffffff.00.0006
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
Initializing SMART SectorsFailed sys sect. write
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
T>((VALID Cert Disk Code Detected - Revision # .08G
T>Pgm=00 Trk=FFFFF(15F15:00[170AF]).1(1).004(FFF) Zn=0 Err=00 ErCt=0000 Hlth=0018 CHlth=0000 Ready LBA=00000C1B
T>
F>R1
Spin Ready
F>R2
F>j,,1
T>R
Code - 74 Track 00000(15E23).0.000 Sns 000 Rty F7FF.40.80FF Rtf 1800 LBA 000000EF
T>
Code 74 after tried to load System Sectors, So its a Defect list problem right?
What do u think
Best Regards
Sinceraly
Alberto
 Post subject: Re: Seagate Tonka 2 160 GB problems
PostPosted: June 5th, 2008, 23:57
Beto i think this is media isssues, the platter is damaged. Try reversed clone.
PostPosted: June 6th, 2008, 0:02
hello friend
now its not reaching readiness:( i was checking some, this day i tried to read SA, and was sucess to read Ata overlay, and read Cert, but when i tried to read Vendor track, was sucess but with some error´s on sectors
"ECC errors" and Sync byte data error. i tried to rewrite but i cant read on that zone and i cant write
Best regards
PostPosted: June 6th, 2008, 14:49
beto wrote:
hello friend
Best regards
Beto ,
you Deleted the G List ???????????
Users browsing this forum: No registered users and 82 guests
