 Post subject: WD1500ADFD UNCR IDNF
PostPosted: June 10th, 2008, 12:20
I've a WD1500ADFD but in mhdd or victoria it shows WD1500BB with capacity less then 150GB. When i do scan, it starts scanning and after LBA 31744 it start showing Bad sector for the rest of the drive. Error include UNCR and IDNF. Also when i try to image it, its doing a power reset once it hit that sector. Any help would be appreciated.
 Post subject: Re: WD1500ADFD UNCR IDNF
PostPosted: June 10th, 2008, 12:30
Also getting AMNF
PostPosted: June 10th, 2008, 12:35
Did you try to continue the image after this point + some MB?
It looks like if the drive hits this LBA, gives up the life....
Regards,
Janos
PostPosted: June 10th, 2008, 12:37
Imaging software freezes once it hit this LBA and reset power.
PostPosted: June 10th, 2008, 12:41
Another smarter program? :wink:
Try to jump up to 1GB and start from there...
Janos
PostPosted: June 10th, 2008, 13:16
Sounds like bad heads.
www.datarecoveryne.com
PostPosted: June 10th, 2008, 14:14
Hi ,
If you Have the right tools Try To Do a Firmware Check And All checks Other then the heads ,If all Ok,Or for that Matter you Get error in Sa Modules Read etc also ,Its definately a Head Issue
PostPosted: June 10th, 2008, 14:20
I've checked it with salvationdata wd doctor and i am getting error "Error loading SA Map" when trying to detect HDD in auto mode. I dont know its SPT info for manual try.
PostPosted: June 10th, 2008, 14:36
Hi ,
As i Have Just the Seagate Tool and Not the Other Tools I Will Try to read and tell you ......wait for my reply in the morning .
PostPosted: June 15th, 2008, 14:05
Either bad heads or damaged firmware module.
This drive is not supported by WD Doctor, hence the error.
