 Post subject: Fujitsu MHT2060AH pcb repair
PostPosted: June 19th, 2008, 12:39
A local computer shop was imaging this MHT2060AH drive then it apparently died. Maybe they had an accident but won't say?
Anyway the drive now appears to be dead.
A protection device with the letter Z or N next to the ide interface power in was open circuit.
There is a short near the motor controller ic TS2255 and after lifting a couple of components it looks like the chip has shorted.
I have tested the drive with a different series MHT2040AT model board and the drive will spin up so i'm hoping there is a chance to get the data by changing the pcb or components.
Another drive is on its way but what would be the best way to attempt a repair?
Is it best to swap the M29F**** rom to an identical pcb from a doner drive? Are there problems with this?
Or should I replace the motor ic and any other parts on the original pcb?
I have searched the site but havn't found a definitive answer for this model drive.
Thanks!
 Post subject: Re: Fujitsu MHT2060AH pcb repair
PostPosted: June 19th, 2008, 23:17
If you can find a drive with the same firmware, e.g. xxxx-8162, then a board swap should suffice. However, you can certainly swap the ROM on a PCB with different firmware.
Jon
http://www.datasaversllc.com
PostPosted: June 27th, 2008, 8:20
Thanks for the info.
Fortunately I didn't have to go for the pcb repair or swapover.
While having a casual chat with one of the guys they mentioned they had a spanned ghost image taken from the drive. They presumed because they were unable to browse the image using ghost explorer the image was no good.
Wrong assumption!
I took the image from them and forced a restore from image by ignoring any error. The image did have errors.
After the drive showed as RAW so then I performed a simple software recovery on the drive and got back what looks like a 100% recovery, 40gb of docs & pics, pst etc.
I did check and with a bit of tweaking the recovered system was bootable.
Users browsing this forum: Google [Bot] and 72 guests
