 Post subject: some advice needed
PostPosted: June 30th, 2008, 11:33
Hello guys...
I have this HDD which was showing No interface age! interminal.
here is what I tried to do to Repair it:
Interface task reset
1024k x 16 buffer detected
ALPINE - 1_Disk M.14 01-16-03 11:51
Head Mask 0000 - Switch to full int.
Spin Ready
3.08 02-19-04 15:08
(P)PATA Reset
Not Interface Age!
T>N50,,22
Code - 33 Track 0E32F.0.000 Sns 000 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>Age=50 Type=20 MxCyl=16358 MxHd=0 MxSct=294 BSz=0000 TCode=0000
T>(Interface task reset
Spin Ready
3.08 02-19-04 15:08
(P)PATA Reset
Not Interface Age!
AutoRd Err 47 at 00e32f.00.0004
T>N50,,22
Code - 33 Track 0E32F.0.007 Sns 007 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
Spin Ready
3.08 02-19-04 15:08
(P)PATA Reset
Not Interface Age!
T>
T>N50,,22
Code - 33 Track 15050.0.000 Sns 000 Rty F7FF.FF.80FF Rtf 1800 LBA 00000000
T>#
Enter Drive S/N 3LJ1FY0X
Enter Packwriter S/N 3LJ1FY0X
T>N2,,22
T>(No valid SeaDex script in buffer.
Begin Test 02
ASCII logging on
Not Power Cycling
Not Power Cycling
Zone 00 Head 00 adaptives set to defaults
Zone 00 Head 01 adaptives set to defaults
Zone 00 Head 02 adaptives set to defaults
Zone 00 Head 03 adaptives set to defaults
Zone 01 Head 00 adaptives set to defaults
Zone 01 Head 01 adaptives set to defaults
Zone 01 Head 02 adaptives set to defaults
Zone 01 Head 03 adaptives set to defaults
Zone 02 Head 00 adaptives set to defaults
Zone 02 Head 01 adaptives set to defaults
Zone 02 Head 02 adaptives set to defaults
Zone 02 Head 03 adaptives set to defaults
Zone 03 Head 00 adaptives set to defaults
Zone 03 Head 01 adaptives set to defaults
Zone 03 Head 02 adaptives set to defaults
Zone 03 Head 03 adaptives set to defaults
Zone 04 Head 00 adaptives set to defaults
Zone 04 Head 01 adaptives set to defaults
Zone 04 Head 02 adaptives set to defaults
Zone 04 Head 03 adaptives set to defaults
Zone 05 Head 00 adaptives set to defaults
Zone 05 Head 01 adaptives set to defaults
Zone 05 Head 02 adaptives set to defaults
Zone 05 Head 03 adaptives set to defaults
Zone 06 Head 00 adaptives set to defaults
Zone 06 Head 01 adaptives set to defaults
Zone 06 Head 02 adaptives set to defaults
Zone 06 Head 03 adaptives set to defaults
Zone 07 Head 00 adaptives set to defaults
Zone 07 Head 01 adaptives set to defaults
Zone 07 Head 02 adaptives set to defaults
Zone 07 Head 03 adaptives set to defaults
Zone 08 Head 00 adaptives set to defaults
Zone 08 Head 01 adaptives set to defaults
Zone 08 Head 02 adaptives set to defaults
Zone 08 Head 03 adaptives set to defaults
Zone 09 Head 00 adaptives set to defaults
Zone 09 Head 01 adaptives set to defaults
Zone 09 Head 02 adaptives set to defaults
Zone 09 Head 03 adaptives set to defaults
Zone 0A Head 00 adaptives set to defaults
Zone 0A Head 01 adaptives set to defaults
Zone 0A Head 02 adaptives set to defaults
Zone 0A Head 03 adaptives set to defaults
Zone 0B Head 00 adaptives set to defaults
Zone 0B Head 01 adaptives set to defaults
Zone 0B Head 02 adaptives set to defaults
Zone 0B Head 03 adaptives set to defaults
Zone 0C Head 00 adaptives set to defaults
Zone 0C Head 01 adaptives set to defaults
Zone 0C Head 02 adaptives set to defaults
Zone 0C Head 03 adaptives set to defaults
Zone 0D Head 00 adaptives set to defaults
Zone 0D Head 01 adaptives set to defaults
Zone 0D Head 02 adaptives set to defaults
Zone 0D Head 03 adaptives set to defaults
Zone 0E Head 00 adaptives set to defaults
Zone 0E Head 01 adaptives set to defaults
Zone 0E Head 02 adaptives set to defaults
Zone 0E Head 03 adaptives set to defaults
Zone 0F Head 00 adaptives set to defaults
Zone 0F Head 01 adaptives set to defaults
Zone 0F Head 02 adaptives set to defaults
Zone 0F Head 03 adaptives set to defaults
Head Mask 0000 -
Read Bias - Head 0 1 2 3
A A A A
HiTemp Bias Head 0 1 2 3
A A A A
Spin Ready
Ref Trk Tan Timing Skew (h0 to h0) = 0000 servo clocks.
ID-OD Delta Timing Skew (h0 to h0) = 0000 servo clocks.
Ref Trk Tan Timing Skew (h0 to h1) = 0011 servo clocks.
ID-OD Delta Timing Skew (h0 to h1) = 0012 servo clocks.
Ref Trk Tan Timing Skew (h0 to h2) = 0012 servo clocks.
ID-OD Delta Timing Skew (h0 to h2) = 001B servo clocks.
Ref Trk Tan Timing Skew (h0 to h3) = 001C servo clocks.
ID-OD Delta Timing Skew (h0 to h3) = 0782 servo clocks.
Calibrating Physical Track 0 on heads 0 thru 3
Calibrating Head 0 ...
GC Seek Error 2 !!!
$Switch to full int.
!!! Adaptives corrupt !!!
AbEnd Test 02
The F> repair could not finish I believe becaseu of the corruption on the Boot Adaptives.
Is there any way I could go bout this at this point?
 Post subject: Re: some advice needed
PostPosted: June 30th, 2008, 13:56
I already tried two different Donors to load the CERT, CERT tab and APP to the HDD and do a F> repair. but with the forst donor adaptive corruption comes up. with the 2cond donot the util hadngs when loading the CERT tab module, for ever.
I do not know if the problem is that the CERT code and table from the donor are bad, or there are other problems causing this curruption.
HDD info ST3160021A, 3LJ1FY0X, 3.08 Barracuda 7200.7.
If the problem is indeed a possible corruption on the Donor's SA objects Firmware then I would be very thankfull if some1 could help me out with it.
thanks in advance
Pedro E.
PostPosted: July 6th, 2008, 12:13
Check there is error 33 that means Adaptives are not loaded .
Users browsing this forum: No registered users and 294 guests
