 Post subject: HTS541001G9AT00 Won't ID
PostPosted: June 30th, 2008, 21:14
Hi DR experts!
I have a drive that goes ready, but will not ID. I can use a loader file and access the SA. In SA-A, modules DIAG, ELG1 and ELG2 gave errors when I backed them up. Also, in SA-C(factory mode), PSHT and RSVD gave read errors when I tried to back them up.
Any insight into what these modules hold and if they're contributing to the problem? I check the NVRAM and it tested out ok(using Salvation Data tool).
Thanks for replies.
A
 Post subject: Re: HTS541001G9AT00 Won't ID
PostPosted: July 1st, 2008, 8:08
Update: The folks at Salvation data are telling me that I have a problem with the PSHT(P-List) module. I've fixed that(copied it from teh SA-C). Now I get zero errors from SA-A and SA-B. Any ideas on what might be causing this drive to go from ready(DSC,DRDY), then give IDNF when it's IDed?
Thanks for help.
A
PostPosted: July 1st, 2008, 8:33
Anyone had any luck rebuilding the P-List by (1) Clearing the P-List, (2) checking for bad sectors from beginning to end and (3) adding them to the "new" P-List?
Users browsing this forum: No registered users and 313 guests
