 Post subject: Seagate ST31000342AS recover data
PostPosted: July 14th, 2016, 6:18
Hallo,
I'm a newbie from this world and i'm really interesting to know more about it
I have this HD, it comes from iMac 2009 24".
The issue is :
1. hd start
2. heard a four times noise than stop
3. if you place your ear, you heard HD spin.
I did a research and seems like a HD death sound. I've tried to replace a motherboard with a similar firmware but made the same issue
System recognize HD only with data rescue or disk drill or terminal ( diskutil list )
Also I've tried to copy with dd from terminal. He did it but there are no data.
Could be something on motherboard? Or inside HD? Can I move firmware chip to another motherboard and recover data?
I must to ask a data recover specialist?
Thank you :) :)
 Post subject: Re: Seagate ST31000342AS recover data
PostPosted: July 14th, 2016, 18:17
if drive clicks and stop spinning after, so problem in heads and you need to go to pro.
PostPosted: July 15th, 2016, 4:32
+1 Exactly so :-(
Users browsing this forum: No registered users and 88 guests
