 Post subject: help toshiba MK8032GAX tips for pcb swap
PostPosted: July 11th, 2008, 7:08
i got this drive and the head is stuck.. fix done
but it can't spin. then i try to test the PCB, no output power from 4 point that connect to the motor.
i search for the donor and got it. all are same only SN is different.
i am not sure that i can just swap the PCB or not. i heard that i must solder and unsolder ROM Chip or CPU.
can you help me which one the ROM that i must unsolder n solder to donor pcb.
no. 1 or no. 2
File comment: MK8032GAX PCB
thanks before
 Post subject: Re: help toshiba MK8032GAX tips for pcb swap
PostPosted: July 11th, 2008, 8:31
It's #1. You're lucky . . .
http://www.datasaversllc.com
PostPosted: July 11th, 2008, 8:52
thanks jono. i will try it..
PostPosted: July 11th, 2008, 19:18
How did you measured this?
The spindler is servo motor, not working with DC power.
Regards,
Janos
PostPosted: July 12th, 2008, 6:44
i measure from the pcb. not from the drive. :wink:
PostPosted: July 12th, 2008, 7:09
Did you use oscilloscope?
Janos
PostPosted: July 12th, 2008, 8:31
you can either use oscilloscope or dmm, but best is oscilloscope.
PostPosted: July 13th, 2008, 2:15
hardly anyone knows what a oscilloscope :roll:
if im right number two chip is a bga type you wont be able to remove
as the solder is under the chip itself so no pins are shown
special tools can remove that chip like what we use :mrgreen:
PostPosted: July 13th, 2008, 20:57
tried it and succeeded. thanks to jono-ats.
Janos
i use multimeter, use a dc tester.
the bga chip can be remove using blower or infrared solder.
PostPosted: July 14th, 2008, 2:15
yes correct but a lot of people just use a blower or painter stripper heat gun
which can damaged the ic again you wont get the perfect connectiong
infrared solder is what we use
Users browsing this forum: No registered users and 256 guests
