 Post subject: SEagate Baracuda 7200.9 St3160211as not detected
PostPosted: July 23rd, 2008, 5:39
I have SEagate Baracuda 7200.9 St3160211as Sata Hard disk drive.
with firmware 3.AAE.
By few time software reset. it is detecting the hard disk, the drd and dsy light is continusely on and also busy light is on.
The terminal log is below.
Data is important. I have not same type of pcb so I can check?
DiskAccess ReadSector EC=43 at 00389d.00.0004
CE Log ErrCode=37 LBA=2a265fd Type=5 Add To Pending 2a265fd
AT Er 00 Nwt Er 37 RdWr 0389d.00.0005
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: 9ff79ffAT Er 00 Nwt Er 43 RdWr 0389d.00.0006
Niwot: 9ff79ff7 b6 9ff79ff7.0.88d 0000 005f 0000 0000
DiskAccess ReadSector EC=43 at 00389d.00.0006
CE Log ErrCode=43 LBA=2a265ff Type=5 Add To Pending 2a265ff
AT Er 00 Nwt Er 43 RdWr 0389d.00.0007
DiskAccess ReadSector EC=43 at 00389d.00.0007
CE Log ErrCode=43 LBA=2a26600 Type=5 Add To Pending 2a26600
AT Er 00 Nwt Er 47 RdWr 0389d.00.0008
DiskAccess ReadSector EC=47 at 00389d.00.0008
CE Log ErrCode=47 LBA=2a26601 Type=5 Add To Pending 2a26601
AT Er 00 Nwt Er 37 RdWr 0389d.00.0009
DiskAccess ReadSector EC=43 at 00389d.00.0009
CE Log ErrCode=37 LBA=2a26602 Type=5 Add To Pending 2a26602
AT Er 00 Nwt Er 37 RdWr 0389d.00.000a
DiskAccess ReadSector EC=43 at 00389d.00.000a
CE Log ErrCode=37 LBA=2a26603 Type=5 Add To Pending 2a26603
AT Er 00 Nwt Er 37 RdWr 0389d.00.000b
DiskAccess ReadSector EC=47 at 00389d.00.000b
thanks,
amit shah
 Post subject: Re: SEagate Baracuda 7200.9 St3160211as not detected
PostPosted: July 23rd, 2008, 13:56
Hi Amit
In your case it's dirt or weak head. Need to be replaced to get data.
DF :D
DF :)
www.datatracksystem.net
PostPosted: July 24th, 2008, 4:50
Thanks for the suggestion.
I have other 160gb sata hard disk. it is baracuda 7200.10 and firmware is 4.A.
and the faulty hard disk has firmware 3.aae and is baracuda 7200.9.
How to identify head will work or not in seagate family sata hard disk drive?
is any method to identify the head will be match or not?
Thanks,
amit shah
PostPosted: July 24th, 2008, 11:21
just check model/ site code / capacity, are same, for these hard disk
DF :)
DF :)
Users browsing this forum: No registered users and 196 guests
