 Post subject: Samsung sv0401h Vango 5 times click and spin stop.
PostPosted: July 25th, 2008, 2:34
I have samsung sv0401h Vango family hdd. Terminal shows
spn0k
+h: 0000
h: 0000
h: 0000
h: 0000
h: 0000
eng>srv>
while applying power motor spins and head move 5 times. after that motor spin is off and no signal in ata register.
what will be the problem?
thanks,
amit shah
 Post subject: Re: Samsung sv0401h Vango 5 times click and spin stop.
PostPosted: July 25th, 2008, 3:09
Head - stack - or fw.
PostPosted: July 25th, 2008, 3:15
after giving 2 times software reset hdd giving readiness.
but while testing sa area and modules, Head click and error comes.
Thanks,
amit shah
PostPosted: July 25th, 2008, 3:43
no communication is coming from the head stack so its more likely damaged
the next opion you can try is buy another logic board
and see if the drive works
if it does not work your looking at a faulty damaged head stack
PostPosted: July 25th, 2008, 9:05
Looks like head problem but u can tried an hot swap, with donnor if the hdd doesnt knock if reach readiness DRDY DSC , so could be a SA problem, on that case u should be on first backup , then check all SA
we got some cases samsung wich knocks, where´s doesnt had MHA problems, even the log show´s like Head H0000+ or H0001+
PostPosted: July 25th, 2008, 10:24
You don't actually mean "hot swap" as I understand it, do you?!
Sounds a bit crazy...
PostPosted: July 25th, 2008, 13:34
I checked my stats, check the m/c for errors especially in err list. Try composite reading. I have a proprietary solution so don't know how to do with PCI, anyway via ata u.v. Commands you can try accessing the m/c. Maybe error lists have errors, or translator issue?
PostPosted: July 25th, 2008, 15:23
After giving reset signal did u check the user area ? If it was full of bad sector which cannot be removed by writing then its a head issue .
PostPosted: July 26th, 2008, 9:22
Rameez, error in Alist give same symptom!
PostPosted: July 26th, 2008, 15:09
When Alist is overflowed the drive knocks and spins down but after reset i have seen most of the time user area is good but if heads are bad then hdd full of bad sectors .
Users browsing this forum: munkygrunge and 288 guests
