 Post subject: HITACHI deskstar 250gb sata Motor Jam (no spin)
PostPosted: July 25th, 2008, 2:24
I have Hitachi deskstar hard disk drive has 2 plate and 4 head.
The hard disk is not spining. So I have open the cover and check the hard disk motor. I have applied force to move the motor, but it is jam, no move.
While appling the power head is moving on plat and when power off the head are come back to park. I have applied force to motor when power is on. But nothin happen. Motor remain in same condition.
What to do for the spin?
data is important.
thanks,
amit shah
 Post subject: Re: HITACHI deskstar 250gb sata Motor Jam (no spin)
PostPosted: July 25th, 2008, 2:35
spindle seized not much you can do unless you know how to do a platter swap
you could allways try and heat the motor side up of the spindle up with a hair dryer
we call them the death star in the trade
as they are well know for failing.
does the hard drive pickup in the bios at all or is not detected
PostPosted: July 25th, 2008, 2:51
hard disk is not detected in bios.
thanks,
amit shah
PostPosted: July 25th, 2008, 3:40
when the hard drive boots up does the drive try to spin at all ?????
are you sure its seized
the next option would be a total platter swap from the bad drive to a good drive
try and heat the underside of the motor see if that helps you out
PostPosted: July 25th, 2008, 5:41
Hi amit shah
As far as I known , a motor seized HD definitely can not be detected by BIOS. It is because the FW stored on PCB and Platter SA. Some WD can be recognized but it is only the series (the info on the PCBA), not the correct HD info. (this is the why we can solve some proble by doing Hotswap).
There is no special tool for motor seizure, so you may need swap platters on a mataching working chassis and extract the data.
I hope it can help in some ways.
Best regards
Laura
SalvationDATA--Profesionnal Hard drive solution Provider. MSN: sales.laura@salvationdata.com
PostPosted: July 25th, 2008, 7:45
I have air gun for the Ic soldering.
I have set the air volume maximum and temp. setting is low. It becomes my hair daiyer.
I have given approx. 5 min. on motor at the pcb side. But no result.
Can I give more? or can I have to heat at the platter side?
thanks,
amit shah
PostPosted: July 25th, 2008, 8:09
do you have a blow torch? :D it will not work....if the motor is jammed, nothing you can do to fix it, platters must be removed.
PostPosted: July 25th, 2008, 9:01
On hitachi 3.5" if u take off platters even with the HPE, its very probable the hdd doesnt reach readiness, its very difficult the alignment :( and got readiness
PostPosted: July 25th, 2008, 9:30
Screws on the hub has a properly selected torque, i.e with a torque adjustment screwdriver it will solved this problem.
PostPosted: July 25th, 2008, 22:52
What part of India do you live Amit. As I am also from India. may be i could help you.
PM me
DF :)
DF :)
www.datatracksystem.net
PostPosted: July 26th, 2008, 3:37
PM me
DF :)
darkforce1,
Near Ahmedabad, Gujarat.
thanks,
amit shah
PostPosted: July 26th, 2008, 8:59
No amount of heat will fix this drive.
You have 2 options:
1) Platter swap
2) Design a tool (if you don't already have one) which screws onto the spindle hub. Apply lots of torque and with some practice and patience, you can get the motor spinning.
If the motor is badly damaged, then you may have to resort to a platter swap.
Data Recovery Ireland
PostPosted: July 27th, 2008, 10:22
Has anybody ever seen what those motors look like? Its impossible to guess how to break it loose unless we knew the structure of the thing and what may be broken off and jambed. I cant see a greasy bearing being siezed up. Even with age and dryed out, they just tend to wallow out and loose precition causing head crashes. All my bad drives get sent in for exchange, so I have never had the opertunity to fully disect a late model drive.
PostPosted: July 28th, 2008, 5:07
You have 2 options:
1) Platter swap
Good Idea , I am also planning for such type of tool. I have used small screwdirver, and put it in the hole of motor empty slot. and applied lots of torque. Result Scredriver is break. Motor is remain in same state.
PostPosted: July 28th, 2008, 13:02
you could pop the back cover of the motor, using a hole saw or similar. the fluid motor often jams with bits of crap stuck in, releasing the fluid and crap and it should spin for a while.
this is of course a very very last resort, and probably won't work anyway :wink: enough disclaimers?
PostPosted: July 28th, 2008, 14:43
The screwdriver is NOT a good idea, there is a real danger that it will slip out of the hole and ruin the platter. In my experience, there is nowhere near enough torque generate to release the bearing this way anyway.
PostPosted: February 15th, 2010, 3:16
is there any solution for Motor jammed except Platters swap.
PostPosted: February 15th, 2010, 7:06
Of the hdd's I've looked at, the bearing is a single sealed component consisting of an outer body of about 11.5mm dia. x 20mm length and a 4mm shaft sticking out one end by about 4mm.
The body is pressed into the stator and the rotor which carries the platters, is pressed onto the 4mm shaft.
I'm working on a wd1600 with exactly the same problem.
Pressing the bearing out and back in is the easy part, doing it with utmost accuracy and without any damage/dust/contamination to the platters is the hard part, plus if you have fixed air guides between the platters and/or a tricky to remove head stack then your problems multiply immensely to probably impossible to diy.
If your data is important, take it to a specalist dr
My data is not important, but would be handy to get some bits back, plus I have the time, patience, access to a lathe and skills to machine up tools, technical/electronic skills, very steady hands, more time and patience, spare good drives of the same make and model to rehearse on, a very clean environment and did I mention time and patience!!
PostPosted: February 15th, 2010, 12:37
Ok, I am not trying to advertise exactly, just answering a question as it is known that I am affiliated with the developers of the tool discussed here - another-platter-transplant-tool-t14686.html
Whilst this tool is currently predominantly for Seagate drives, we have had it working with Hitachi drives, just needs a bit more work to bring it up to an acceptable standard to release.
Secarma Ltd
http://www.secarma.co.uk
Users browsing this forum: Google [Bot] and 110 guests
