 Post subject: Samsung HD501LJ comes reasy but no ID>
PostPosted: August 9th, 2008, 11:03
Any ideas guys?
Drive spins up OK, normal noises. Comes DRDY, but no ID
Terminal says...
SPW 1.5G LinkOk! ADC: 0000
SpnOk
spd: 0000 0000 FFFF
H: +00000
ADC: 0001
DAC: 7F89
Unlatch Tk: 0001806C
Unlatch Done
ENG>SRV>
SvoTbl Loaded
BD
0003
0005
0007
0004
0006
0006
0004
0003
0004
0004
0005
0009
0003
0004
0005
0005
0005
00060401_0000_0000 ENG>
Not come across a Samsung behaving like this, they're usually bad PCB or heads, in my experience.
Any help or suggestions appreciated.
Cheers
Sean
 Post subject: Re: Samsung HD501LJ comes reasy but no ID>
PostPosted: August 9th, 2008, 11:29
Is the M/C 100% OK ? And also why ENG ? Seems a mild firmware corruption, only some module affected. Or maybe ROM.
Can you check and compare with another ?
PostPosted: August 9th, 2008, 12:29
BlackST...
Thanks for the reply!
M/C? Motor Controller?
I must admit, the last time I had a similar problem, the client had swapped the PCB :shock:
I repaired the original PCB, as the ROM was masked. All worked fine with original PCB.
But this one claims he hasn't swapped it!
PostPosted: August 9th, 2008, 13:15
M/C = SA in samsungs... anyway the ROM can get corrupted. I had some drives "clicking" with no obvious damage to M/C ooops... SA . The culprit : rom with defective part. Reprogrammed in-circuit, everything fixed. Anyway it's not a problem if the ROM is masked it's reprogrammable. At least as long as the PCB works and can establish communication.... Remember in samsung there are a lot of codes and downgraded drives (= different code).
Users browsing this forum: Google [Bot] and 47 guests
