 Post subject: HDD Clicking not detect
PostPosted: August 19th, 2008, 0:10
my harddisk not detect, and clicking, what problem? any body can help me to give my data?
 Post subject: Re: HDD Clicking not detect
PostPosted: August 19th, 2008, 0:29
Maybe with some more detail... like brand, model and something similar. Is data REALLY IMPORTANT or can live without? And also... What's your skil level and how much are you willing to spend?
PostPosted: August 19th, 2008, 0:39
can be the following need more information on your drive
1)headstack failed
2)firmware corruption
3)logic board damaged
PostPosted: August 19th, 2008, 2:22
My harddisk is Fujitsu SATA 2'5 160 Giga, i want to give my data. i use many revovery software but cannot detect. what should i do for give my data. may be change sime sparepart.
PostPosted: August 19th, 2008, 3:14
It's not a thing you can do on your own unless you are skilled on servicing this kind of HDDs. Strongly suggested to ask a pro in your area with proper tools and skill who can recover your data (it seems that data is important).
It's not possible to explain how to repair your drive..
Where are you located in order to get contacted by someone here who can help you ?
PostPosted: August 19th, 2008, 3:44
the problem your having is more likely to do with the logic board itself
try and match up with your make and model and firmware
allso match up where it was made too
not sure what it could be put it possible the sata power side has gone down.
does your drive have the 4 pin power plug too
unplug the sata power lead
try this and see what happens
allso does the drive spin up at all can you hear it ??????
PostPosted: August 19th, 2008, 9:48
It is clicking, so most probably it has head problem. It is possible the platter has damages too. So the more it is ran the more severe the damage will be inside the HDA.
So if the data is critical it is crucial to diagnose the problem properly, no mistake is allowed. For this reason I would really suggest to contact a pro nearest to U.
Now Stts, please come and tell how wrong I am and to disassemble the drive and screw up things for the rest of eternity! :)
kind regards,
Users browsing this forum: No registered users and 243 guests
