 Post subject: MHS2060AT 2nd Opinion appreciated!
PostPosted: August 27th, 2008, 9:17
Fujitsu MHS2060AT
Knocking.
Heads check out OK - Donor heads same symptoms, patient heads in donor work fine.
PCB OK - Works fine on donor with ROM reprogram.
No modules readable.
I'm guessing I'm looking at bad media, but it's unusual with good heads, and I don't wanna hear that!
Any ideas guys?
Cheers
Sean
 Post subject: Re: MHS2060AT 2nd Opinion appreciated!
PostPosted: August 27th, 2008, 9:22
Do you have a way to confirm motor speed?
http://www.datasaversllc.com
PostPosted: August 27th, 2008, 9:43
Hi, thanks for the prompt reply!
Not as such.
You think it could be that? You've seen similar before?
PostPosted: August 27th, 2008, 10:28
Hi Sean,
Had such a case a few weeks before. Platterdamage, but invisible to the eye.
I had to give up.
Sorry to bring bad news :-(
Dobre
Murphy was an optimist
PostPosted: August 27th, 2008, 10:39
Hi Marc,
That's just what I didn't want to hear! :-(
I've had this a few times with MHV but 1st time with MHS
Thanks for taking the time to reply though!
Cheers
Sean
PostPosted: August 27th, 2008, 11:09
That's SA problem
Most likely recoverable
PostPosted: August 27th, 2008, 12:14
Hi Doomer, thanks for the reply.
I connected to PC3000 and after a few minutes it stopped knocking and scraping and came DRDY DSC, and entered utility manually.
ROM info was read (correct version matching drive label), and module table found in ROM.
Any attempt to read ANY modules caused the drive to start knocking and scraping again and produce "drive not ready"
Any more clues? ;-)
Feel free to PM me or msn me!
Cheers
Sean
Users browsing this forum: No registered users and 61 guests
