 Post subject: WD800BD-22LRA0
PostPosted: August 29th, 2008, 23:14
NEED ROM for WDC
WD800BD-22LRA0
23 DEC 2006
DSBHNTJCH
any shre will b very appreciated
Спасибо
СУТИОНО / АПИНГ
 Post subject: Re: WD800BD-22LRA0
PostPosted: August 31st, 2008, 21:49
nobody !!!!!
Спасибо
СУТИОНО / АПИНГ
PostPosted: August 31st, 2008, 22:07
I will upload in file section today in PC3000 UDMA and PCI
DF :)
DF :)
www.datatracksystem.net
PostPosted: September 1st, 2008, 1:15
Uploaded
DF :)
DF :)
PostPosted: September 1st, 2008, 3:34
Thanks You friend.. But it is
WDC WD800BD-88LRA0
I dont think it will work with my one... But ANYWAY . THANKS. :)
AP
Спасибо
СУТИОНО / АПИНГ
PostPosted: September 1st, 2008, 4:19
WDC WD800BD-88LRA0
AP
the first 2 numbers in the latter section do not make a difference, 88LRA0 and 00LRAO should be compatible
PostPosted: September 1st, 2008, 4:35
ok i will give it a test
Спасибо
СУТИОНО / АПИНГ
PostPosted: September 1st, 2008, 6:33
I have try reprogram ROM using WDC WD800BD-88LRA0 rom content but
WDC WD800BD-88LRA0 ROM not working with my WDC WD800BD-22LRA0
I still need this WDC WD800BD-22LRA0 ROM
its Original Board was burned seriuosly and burn its ROM too
Please help :)
AP
Спасибо
СУТИОНО / АПИНГ
PostPosted: September 1st, 2008, 7:15
It's not the 88 vs 22 that's the issue, this number only indicates who the drive is made for (Retail WD, Dell, whoever).
The issue is the adaptives in the ROM. You may get lucky by finding ROM from a drive with the same DCM, I had a similar case but fortunately the case was with a RAID 0 set, so I was lucky enough to get a perfect match and the good PCB worked fine on both drives.
PostPosted: September 1st, 2008, 8:30
Even the same DCM doesn't guarantee that the adaptives will match.
I had some cases where a pcb from exact the same drive (same MDl and DCM) didn't work till i replaced the eeprom.
Dobre
Murphy was an optimist
PostPosted: September 1st, 2008, 8:34
Dobre
Sometimes in DR you just have to have a complete disregard for any logic :lol:
PostPosted: September 1st, 2008, 9:06
Dobre
Very true, I just got lucky. The two drives were out of the same box and more or less consecutively serial numbered.
PostPosted: September 1st, 2008, 22:14
Yes. I'm not lucky this time. ROM Burned :(
I have 2 WDC drive here in my stock
it is : WD800BD-22MRA1 / DSBANTJEH / / 18 NOV 2007
and WD800BD-22MRA1 / DBCHNTJCH // 07 OCT 2007
This 2 WD Drive work compatible with Both PCB.
Both got same Model and Different DCM with production date differ One month more.
and Both PCB work in each drive as well...
At Least I need to give a test with the same Model ROM in My defective Drive.
I still hope somebody can send to me the same Model ROM..
Thanks for everybody command and help :)
AP
Спасибо
СУТИОНО / АПИНГ
PostPosted: September 1st, 2008, 22:46
The ROM revision most likely :mrgreen:
Users browsing this forum: Google [Bot] and 231 guests
