 Post subject: Infra Red Soldering Station
PostPosted: August 28th, 2008, 10:33
Currently looking into replacing our current soldering setup with infrared soldering station. This should be more efficient, and also would help us deal with BGA chips/processors.
Anyone have any recommendations on which ones are best, or more efficient for DR?
 Post subject: Re: Infra Red Soldering Station
PostPosted: August 28th, 2008, 10:42
what is your current setup? have you tried the Kakko type hot air with nozzles?
PostPosted: August 28th, 2008, 11:07
Hakko?
They make good quality tools. Not sure of their IR units, but their soldering tools are very good, especially for the price. When I move to IR, I'll get the cheapest unit I can find on Ebay. Then, it will either work fine for me, or I'll know exactly what I need and want with a better brand. I hate making expensive mistakes.
http://cgi.ebay.com/ws/eBayISAPI.dll?Vi ... 0283743213
PostPosted: August 28th, 2008, 11:18
For IR, Metcal is THE choice.
PostPosted: August 29th, 2008, 4:01
if you want to use them for bga chips your better of with infra red
for anytime bga chips
hot air nozzles does not work that great or at all and can damage the ics
the pro way is infra red
would this be ideal for logic boards guys
and possible laptop circuit boards
end of the day how many times do you think your use something like this for
hard drives???????
T862 IRDA Welder Infrared Heating Rework Station
PostPosted: August 29th, 2008, 10:46
not many times u know the most cases with ic´s damaged are SMD¨S
PostPosted: August 30th, 2008, 1:32
Few bgas in hdds... Also reballing is another problem... Ugh!
PostPosted: August 30th, 2008, 2:44
you dont need to reballing all you need is some solder and go over the connections
reballing kits are not really needed
most hard drives we seen have bgas and it sucks when you got to change them
PostPosted: August 30th, 2008, 3:08
One of the big problems with BGA (and some QFP) devices is that there is often a big solder pad on the underside of the chip that is very very difficult to desolder, even with IR at max temperature. On top of that, the chips are sometimes adhered to the board first using a very strong adhesive. It almost like the manufacturers are conspiring against us.
<itch>
PostPosted: August 30th, 2008, 8:13
I agree. There's a solution, anyway.
PostPosted: August 30th, 2008, 11:01
What drives are you seeing BGA's on? I don't think I've seen any yet, but I may not have been paying attention.
For BGA's on notebooks, I just use a heat gun. Seems to fix any small cracks.
PostPosted: August 30th, 2008, 19:36
ibm deskstar
most hard drives are bga these days.
Users browsing this forum: Google [Bot] and 136 guests
