 Post subject: ST3200822A (Many bads blocks)
PostPosted: September 1st, 2008, 16:17
Hi to all!
Please opnion the case!
Necessary date recovery of this hdd, already I tried DE PCI, MEDIA TOOL PRO for data among others recovery and to clone this hdd but without success, somebody already had some here in case that seemed, can give to its opinon?
:shock:
[PRE]HDD: ST3200822A; FW: 3.01;
Name Val Worst Raw
Att # 1 : Read error rate : 52 44 197396991
Att # 3 : Spin up time : 98 96 0
Att # 4 : Number of spin-up times : 100 100 396
Att # 5 : Reallocated sectors count : 89 89 474
Att # 7 : Seek error rate : 86 60 450771832
Att # 9 : Power-on time : 65 65 31182
Att # 10 : Spin-up retries : 100 100 0
Att # 12 : Start/stop count : 100 100 885
Att # 194 : HDA Temperature : 32 55 32
Att # 195 : Hardware ECC recovered : 52 44 197396991
Att # 197 : Current pending sectors : 100 100 540
Att # 198 : Offline scan UNC sectors : 100 100 540
Att # 199 : Ultra ATA CRC Error Rate : 200 187 13
Att # 200 : Write error rate : 100 253 0
Att # 202 : Unknown : 48 201 52
Thanks advance!
Нет ничего невозможного
 Post subject: Re: ST3200822A (Many bads blocks)
PostPosted: September 1st, 2008, 17:50
What did u got on terminal? u could post us the screenshot from mhdd
regards
PostPosted: September 2nd, 2008, 2:55
Degraded head? Maybe a selfscan...
PostPosted: September 2nd, 2008, 4:39
"Maybe a selfscan"????? :shock: .......He needs the data!!!!
www.datasave.ro
PostPosted: September 2nd, 2008, 4:46
Why was it unsuccessful? Was there any successfull reading of any sectors at all?
PostPosted: September 2nd, 2008, 6:07
:roll:
I believe that the friend did not read post all!
Thanks...
PostPosted: September 2nd, 2008, 6:11
Hi hddguy!
it does not obtain to read the bad sectors nor with 30 attempts in bad sectors and hdd stops to answer the commands…
:roll:
Thanks..
PostPosted: September 2nd, 2008, 6:14
Please post terminal report.....
Rgds
www.datasave.ro
PostPosted: September 2nd, 2008, 6:42
OK I forgot it was a DR case.... OK OK :oops:
Yes, terminal log is a little more useful :)
PostPosted: September 2nd, 2008, 9:54
regards
Hi Beto, ccc and others..
look log term
Interface task reset
4096k x 16 buffer detected
APLUS - 1_Disk S.07 01-17-04 11:37
Buzz - Head Mask FFFF - Switch to full int.
Spin Ready
3.01 01-17-04 11:39
(P)PATA Reset
Master
(S)PATA Reset
Master
(H)PATA Reset
Master
AT Er 00 Nwt Er 49 RdWr 00091.02.00f2
ATA St 50 Er 01 Op 00 0,0000/0/00,00 01 00
Niwot: ec45346b ff ec45346b.0.033 0033 408e 0001 00c7
CE Log EC=49 Rtype=26 OV=0 STStatus0
Not handled software path:
PostPosted: September 3rd, 2008, 10:47
Hi, No opinion?? :?: :?:
PostPosted: September 3rd, 2008, 11:03
Not handled software path: <---
The read error parser cause firmware hang
It is pretty common for APLUS and ALPINE models
PostPosted: September 3rd, 2008, 11:42
u can tried a head test by terminal, to know if its MHA problem
PostPosted: September 6th, 2008, 9:40
Please Look
log
log.rar [2.63 KiB]
Downloaded 362 times
PostPosted: September 19th, 2008, 6:32
DATA RECOVERY SUCESS!!!!! :lol: :lol: :lol:
PostPosted: October 4th, 2008, 1:38
How did you fix it?
PostPosted: October 5th, 2008, 2:56
Well Sempre ,
What Was Wrong ,You Should Definitely Post cos the essence of the thread is Gone when you Do Not
Users browsing this forum: Google [Bot] and 53 guests
