Is it poss to read only 1 platter from a multi platter drive
October 16th, 2009, 17:56
Hi forum,,, think i know the answer to this now but thought id post just for my clarification.
I took apart my multi platter drive (TOSHIBA 80GB HARD DRIVE MK8025GAS) a few weeks back seperating the platters and found a scratch all the way around the underside of the bottom platter.
If i get an identical drive and put in the good platter only will i be able to see any data if connecting it via a caddy?
Thanks in advance
Neil
Re: Is it poss to read only 1 platter from a multi platter drive
October 16th, 2009, 18:03
no.
October 16th, 2009, 18:34
Unfortunately not.
October 16th, 2009, 18:55
generally agree with the others, but there is still something....
I am working on a solution for reading platters one by one, and now i can do it on some drive models, but not on all of course.
But i need to add, on your case it is allmost impossible, because it was opened outside of cleanroom.
So if i think about the "normal" price for ths solution + the scored platter-problem, the price is huge.
I mean it is not worth, i am sure.
Simple: No. :mrgreen:
October 22nd, 2009, 3:53
NeilC wrote:
I took apart my multi platter drive (TOSHIBA 80GB HARD DRIVE MK8025GAS) a few weeks back seperating the platters....
Why would you do this anyway?
October 22nd, 2009, 5:57
I have a solution but it's gonna cost £££££££££. Simply NO.
October 22nd, 2009, 12:50
Curiosity. Live and learn!
