 Post subject: IOMEGA USB 2.0 Portable Hard Drive transfer issue
PostPosted: September 9th, 2008, 13:40
When I plug in my hard drive it recognises alright but when I start a large file transfer...half way through the drive just suddenly cuts out and disappears from My Computer ...saying cannot file path la di de da..... it also happens when i try to safely remove hardware it tells me the generic volume cannot be removed......but then the drive just disappears....it also happens when I try and delete something off it...it just tells me half way through cannot find file path and guess what...the drive has disappeared from My Computer....
Slightly off topic but has anyone got any suggestions???
 Post subject: Re: IOMEGA USB 2.0 Portable Hard Drive transfer issue
PostPosted: September 9th, 2008, 16:13
Sounds like a USB and/or power issue. Does your drive have an external power adapter? Have you tried a better/shorter USB cable?
PostPosted: September 9th, 2008, 16:23
seems the usb enclosure problem. try to change to a good one.
__________
THANK YOU
SHAHI
shahi.mahbub@gmail.com
PostPosted: September 9th, 2008, 17:36
What do you mean by 'usb enclosure problem' im not great with computers so if u could elaborate that wud be good..
Thanks.
PostPosted: September 10th, 2008, 14:43
Take the hdd out of the external box and test it in a normal computer .
Users browsing this forum: shubhsinghal and 82 guests
