 Post subject: WD 120GB Safe Mode Problem
PostPosted: September 14th, 2008, 13:03
I have one WD120JB GB Drive and i can't run the utility on Safe Mode.
I have try 2 same PCB one that Drive and i can't use Kernel Mode.
The status of Drive is only always "Busy".
Any Advice Welcome..
T3 Professional Data Recovery
http://www.t3-recovery.com
 Post subject: Re: WD 120GB Safe Mode Problem
PostPosted: September 14th, 2008, 16:48
Are you sure the two PCBs are working and ROMs OK ?
PostPosted: September 14th, 2008, 17:13
Try safe mode with board removed from HDD. If you can read ROM then the problem is most likely heads or Motor.
PostPosted: September 15th, 2008, 5:17
for the BlackST , the 1of 2 the Rom is not working, the second one when i try 20 times to reach the safe mode only ones manage to gain access. After that time always busy led only.
for the Daisy Woo ,i already tried that no access.
When i use any one other PCB who fit to the Drive ,i have platters motor works and Heads clicking , but i can access the drive on safe mode ...
PostPosted: September 15th, 2008, 6:37
I suggest a better match or try finding a known working pcb just to point out if preamp/heads are ok or you'll waste a lot of time.
Users browsing this forum: No registered users and 72 guests
