 Post subject: WD5000AAKS
PostPosted: September 17th, 2011, 12:04
greetings all
first 6% of this was toast, DDI was getting most of it but died in reverse at 2% (rest is ok) up untill now, pretty good recovery.
Heads "were" fine
Would this suggest the heads have packed in? Spins up tries its best but then spins down.
New 3k user.
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is re
Full log
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 96
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 21.7NQ
ROM generation.......................... : 21.7NQ
Link table version...................... : 22.50.
Consolidated ROM version................ : 0021007N
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
Heads configuration..................... : by map
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 2,3,4,5,6,7
ROM Firmware version.................... : 0021007N
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
thanks
andy
Databusters Data Recovery Glasgow
http://www.datarecovery.co.uk/latest-data-recovery-jobs/
 Post subject: Re: WD5000AAKS
PostPosted: September 17th, 2011, 12:06
Yes, sounds like heads have packed up.
PostPosted: September 19th, 2011, 14:47
Most likely the heads are dead now. However id still try a donor PCB with patient ROM on it. U never know... =)
Users browsing this forum: No registered users and 108 guests
