 Post subject: "disappearing drive"
PostPosted: September 13th, 2008, 3:51
I have a 2,5" hdd which will be recognized when starting the computer.
Very shortly after the system is ready a small window appears and an
error message explains that a device was (try to explain to english):
"Unexpected / not permitted removal of a device" - meant is the hdd.
After this, certainly its not possible to access the drive.
I made a complete image with the Ninja from YEC - took about 3,5 hours.
Tested yesterday with Data Compass from Savlationdata - which would have
taken about 13 hours (most probably due to the USB bottle neck).
My question to the pros:
What is causing such an error?
How can Ninja or CD bypass the confict? A matter of (no) BIOS?
 Post subject: Re: "disappearing drive"
PostPosted: September 13th, 2008, 6:30
Hi, was it in windows or linux you get the error?
Maybe its due to the drive failure to respond within a certain time period...'time out'
What happens if you attempt to access the drive in a Dos environment?
PostPosted: September 13th, 2008, 6:42
Sorry, I was not clear enough:
Windows 2000
the drive was detected during boot up
the drive existed in Windows for 20 to 50 seconds - and then the error occured
I did not try with DOS yet.
the image with Ninja was complete and no data was missing - the image works perfectly.
My question was only to understand what happens respectively what can cause such
an error.
Thank you
Users browsing this forum: Google [Bot] and 96 guests
