 Post subject: Samsung SP0802N
PostPosted: September 20th, 2008, 7:48
I've a Samsung drive which is not detecting by BIOS, and its clicking.-------> PATIENT
Model: SP0802N
P/N: 0820J1DY337485
P/V: FA
Rev.D
2005.03
PCB: PACDY3M6A45502 (Sticker on PCB)
Paladin - Rev04 - 2M (Printed on PCB)
Controller IC (Big M): 88i6522-LG01
FH44111.2
I've another Samsing SPO802N drive which is detected by BIOS & working.---> DONOR
Model: SP0802N
P/N: 0904J2FXC07578
P/V: MA
Rev.D
2004.12
PCB: PACDXCJ5A40713 (Sticker on PCB)
paladin - Rev04 - 2M (Printed on PCB)
WB50720A.1
Are these PCBs are compatible with each other for swapping?
The Patient drive with the donor PCB, clicking.
and the Donor(good one) with the patient PCB also clicking.
Is there anything i should do other than swapping the PCB ?
Thanks,
RDS.
 Post subject: Re: Samsung SP0802N
PostPosted: September 20th, 2008, 9:19
The most common problems are MHA, and some times SA, but u check on first if there are not head crash on the land zone over surface
regards
PostPosted: September 20th, 2008, 11:59
Thanks for your reply.
My question is if the problem is with the Patient drive's MHA or SA, then the patient drive's PCBA should work fine with my donor drive. Right?
Thanks,
RDS.
PostPosted: September 20th, 2008, 14:54
Check Rom on both pcbs like TKxxx-yy, then terminal log will make everything clear about the problem. Does a soft reset stop clicking or is stuck bsy? Try sending a soft reset via Ata.
PostPosted: September 21st, 2008, 14:15
Hi
This hard disk mostly had Head issue.
DF :D
DF :)
www.datatracksystem.net
Users browsing this forum: No registered users and 66 guests
