 Post subject: Strange Seagate problem
PostPosted: April 13th, 2008, 2:03
With PC3000 UDMA:
I'm working with a Seagate ST330831AS that stays in busy mode and will not come ready. I've tried two different PCBs, transplanting the ROM each time.
The drive spins up but I can't detect a seeking noise. I have not opened it.
Here's the odd thing: If I remove the PCB from the drive, serial access works fine and the ROM can be read and written. However, once I put the PCB back on the drive the serial access will time out and I can't access terminal mode.
If I do a power cycle within the utility, this is the message in Terminal:
Interface task reset
4096 x 16 buffer detected
Tonka-1_Disk S.00 01-11-05 11:50
However, the drive comes out of busy and all of the user commands time out.
What gives?
Jon
http://www.datasaversllc.com
 Post subject: Re: Strange Seagate problem
PostPosted: April 13th, 2008, 15:51
Hello jono my suggest check the platters we had check , many seagate“s with tendence to head crash :(
Maybe u got a shortcut between PCB and MHA, maybe there are some problems a shorcut on the MHA; last year we got a Hitachi problem, on that case i put a piece a paper between the MHA flex connection and PCB, to know the problem and the solution
Best Regards
Alberto
PostPosted: April 13th, 2008, 16:21
Thanks, Alberto. I'll try the paper over the MHA contacts. Some drives require communicating with the MHA before they will POST and spin up. I seem to remember that Seagate is one of them, but I'll soon find out.
Jon
PostPosted: September 22nd, 2008, 6:51
I have same problem for the segate ts3250823ace db35.1 family harddisk.
can you have get any solution for your poblem?
thanks
amit shah
PostPosted: September 22nd, 2008, 9:34
If I recall correctly, there was a short in either the VCA or the head stack that caused this problem.
Jon
PostPosted: September 22nd, 2008, 12:13
Jon, i vote for you have some preamp problem.
I suggest, to replace, and try it again....
Regards,
Janos
Users browsing this forum: Google [Bot] and 61 guests
