 Post subject: What SMD station do you recommend?
PostPosted: August 25th, 2010, 8:45
Hi all,
I want to buy one of those SMT staion.
What do you recommend?
http://shop.ebay.com/i.html?_nkw=smt+st ... m270.l1313
Many Thanks!
 Post subject: Re: What SMD station do you recommend?
PostPosted: August 25th, 2010, 14:42
Sorry for the double posting.
At the first time I thought that my post hasn't been published so I wrote it again.
PostPosted: August 25th, 2010, 19:30
What do you say about this station?
http://cgi.ebay.com/AOYUE-968-SMD-SMT-H ... ment_Tools
I don't know about this anything, so I going to trust on you guys 8)
Many Thanks!
PostPosted: September 28th, 2010, 1:24
stick with a good brand
we use the
Aoyue 2702A+ SMD/SMT Hot Air All in 1 Rework Station
they redesign the solder gun now so it works a lot better.
its good for smd work and it has Microprocessor Controlled ESD safe unit
watch out for the older version as they dont have the redesign solder gun
enclose is there information they are very helpful
http://www.sra-solder.com/smt_rework.htm
USA
Stan Rubinstein Assoc.
56 Leonard Street,
#2 Foxboro, MA 02035 USA
Tel: 1-800-545-4570
   1-508-543-4111
randy@sra-solder.com
PostPosted: September 28th, 2010, 4:44
Wasting time with air guns
If you want to invest go with the future!
http://www.zeph.com/airbathseries.htm
You can also use this with something called quickchip / chipquick which is absolutely amazing!
I use a similar pcb heater & 50-70degrees Celsius with a smd tool- 10 minutes hassle free transplant even large SMD's - easy peasy.
Oh and for soldering Iron buy a Weller Station with replaceable tips. You can get temp controlled or static tamp. They last for years - I still have my dads as backup 15+ years old! i have a new one with temp control for SMD resolder and special tips
Free Solutions
PostPosted: September 28th, 2010, 9:19
For SMD I use Philips hot air and infrared for different packages like BGA/CSP.
For soldering, happy with ELV, GOOT, Weller and Philips. What matters is the availability of spares and tips.
90% is skill and the ability to use chemicals and tool, not the equipment itself.
Have seen disasters using the most expensive equipment on the market ?)
PostPosted: September 28th, 2010, 9:54
Philips hot air ? Really :D :D
joke :P
Free Solutions
PostPosted: September 28th, 2010, 10:47
Well, i dono much about brands really and tech. in this issue but i got mine, Chinese made, good one (at least solves my problems here) and when the time comes for high end i might spend few hundred $$ in a good one
IF AND ONLY IF am gonna get my money back from it
its like buying a car, you don`t need to buy a Ferrari to Practice Driving, may drive KIA for example, and when you think you need something more Pro. for ur work, go for the high-end my friend.
this is my Rule, hope am right :oops:
PostPosted: September 28th, 2010, 16:30
I need hi end tools with spares even after years. Philips and weller are perfect under this aspect, a little less about price, but it's secondary : paid by themselves.
