disassembly monolith flash drive
August 2nd, 2013, 22:26
more details photo http://www.rflashdata.com
monolith pinout
monolith pinout.jpg (62.31 KiB) Viewed 8398 times
monolith flash drive data recovery
monolith data recovery
disassembly monolith flash drive for data recovery
Re: disassembly monolith flash drive
August 2nd, 2013, 23:09
Nice :-)
data surely not recoverable after this.. this is a demo of what internals look like isn't it?
What magnification is that at around 100-200x ?
really cool!
August 3rd, 2013, 2:30
i think data still can be recoverable. as chip no damaged.
for this case. it's bad donor drive. pinout made. but i have problem with read dump so i want to check inside connection.
how many X i am no sure. around 60~80X only
August 3rd, 2013, 2:39
I hope you can get data, good luck.
So how do you connect wires to something so small. I thought it was hard enough to connect to the regular row of 40 pads on the outside of the monolith, but this is a whole different level.
It is really interesting to see things Ill never see in the flesh, so thanks again.
August 3rd, 2013, 22:56
this case connect wire easy.
http://www.rflashdata.com/kingston-1g-sd/
it's hard for me. i make this solution with luck. need improve skill for process such case. as many case like this.
