 Post subject: Digital Photo Frame Hacking
PostPosted: January 30th, 2015, 5:08
Hi Gurus.
I have a Digital Photo Frame here.
my problem is that Digital Photo Frame have 2 memories, one easily accesible but but other not easy accesible.
The digital Photo Frame comes with 2 videos, 1 video is stored on not easily memory access, and i want to delete both videos.
Any of you knows any tool to access to this memory and delete video?
Thanks in advnaced
 Post subject: Re: Digital Photo Frame Hacking
PostPosted: January 30th, 2015, 8:31
The devkit of these are usually easy to find.
Might help a LOT :-) if you post the make of the frame, or better the chipset, photos, memory details etc.. there are quite a few of these about.
You haven't told what the memories are, NAND, other or much at all.
Post up some more stuff and lets get to hacking! :)
PostPosted: February 2nd, 2015, 7:23
Thanks HaQue, ill speak with customer to get 1 digital frame here.
If i have news ill report here.
Thaks another time.
PostPosted: February 2nd, 2015, 8:55
I have a couple of key ring photo frames intended for research into DR in case any customer wanted one recovered... Ok that's the story I tell when I want to hack a device .. I am guessing you are talking about the 7" ones and the like? I have some of those too..
If you get me sidetracked into having some fun with these there will be trouble! ;-)
PostPosted: February 2nd, 2015, 16:28
I expect that these devices would have an embedded Linux OS. If so, then there may be a way to telnet into it via a serial port, or perhaps there is a JTAG port.
Here is an example of such a project:
https://sites.google.com/site/repurposelinux/df3120
PostPosted: February 2nd, 2015, 20:44
I think they ported Linux to it, but the frame wasn't running Linux to start with. it isn't really clear to me in any case.
This is another good resource:
DPF with AppoTech AX206
http://picframe.spritesserver.nl/wiki/index.php/DPF_with_AppoTech_AX206
and our old friend Jeroen (Sprite) from spritesmods.com
Use a cheap digital photoframe as a second display for your PC
http://spritesmods.com/?art=picframe
