 Post subject: Full Format empty 256GB USB Flash FAT32 to NTFS takes 8 min?
PostPosted: December 22nd, 2015, 13:41
Hi guys,
I bought Transcend 256GB 3.0 USB Flash Drive, it was formatted to FAT32.
I saw the Serial Number from the USB Flash Drive and entered it on the Transcend website and it says it is genuine.
My laptop has only USB 2.0 ports.
I copied 9.83 GB of data on the USB Flash and after that I copied the same data from the USB Flash to the PC again, and all was OK.
Then I deleted all 9.83 GB of data from the USB Flash.
Then I decided to convert the FAT32 to NTFS with Full Format, and it took around 8 min.
I thought the convert time was too fast and tried again to convert to NTFS with Quick Format which took around 45 sec.
Than I decided to do another Full Format to NTFS, this time from Disk Management, and it took around 8 min again.
I expected the Full Format to last around 2 hrs, at least that's how long it will take for a Hard Drive I think.
I don't have much experience with formatting 256 GB USB Flash Drives, maybe it was fast because it was empty? I am not sure.
What do you guys think?
Is 8 minutes normal time to do Full Format on an empty 256 GB USB Flash Drive?
 Post subject: Re: Full Format empty 256GB USB Flash FAT32 to NTFS takes 8
PostPosted: December 23rd, 2015, 2:18
Use rufus to do a full format
Recover My Flash Drive
PostPosted: December 24th, 2015, 15:14
Thanks, I will give it a try.
