 Post subject: Corrupted TrueCrypt Partition (header)
PostPosted: November 28th, 2015, 14:23
I have the same problem like OP from this thread: http://www.wilderssecurity.com/threads/ ... on.327959/
I couldn't reply in the old thread, so I have to create a new one..
I recently allowed Windows to initialize the drive and that destroyed the header.
1) This is what I had at the beginning. I was able to mount my drive in TC:
but unfortunately I was not able to see any data, there was no partition:
2) Then I created in WinHex partition's starting offset file: Test Outer.tc
I used starting block 1048576 and ending block 5048575
I was able to mount this file in TC, so everything went well
3) I have created partition in DISKPART
(Create partition primary offset=1024)
4)now I see partition in TC, but I can not mount it because I get error message
"incorrect password or not a TrueCrypt volume":
5) now I have header's copy in file Test Outer.tc , partition on my encrypted hard drive (but I can not mount the drive anymore longer because of "incorrect password")
now in WinHex i probably need to restore Test Outer.tc to the disk
post number 19 in this thread described this:
http://www.wilderssecurity.com/threads/ ... st-2089995
but I dont know how to do that and I dont want to experiment
Could someone help me? I think I am pretty close to succeed
 Post subject: Re: Corrupted TrueCrypt Partition (header)
PostPosted: January 2nd, 2016, 4:49
bump, can anyone help?
PostPosted: January 2nd, 2016, 8:13
I have seen this situation a couple of times when in my cases Windows appeared to 'repair' the partions and so damaged the Truecrypt header in the process. So do you have a rescue disk?
Have you previously made a full image of the drive? If the answer is no then I suggest you do that right now!
Normally I would boot from the rescue disk and either repair the header or run a full drive decrypt. Have you tried booting from a cd or usb and decrypting with your known password? You would then run software recovery tools to scan for the partition and files if required.
I know my suggested procedure is the easy method. Maybe you have already exhausted these options?
PostPosted: January 7th, 2016, 16:12
Unfortunately I dont have Rescue Disk
i belioeve that the answer for my problem is in this and next post:
