 Post subject: samsung MZRPA SSD to sata
PostPosted: February 10th, 2016, 16:01
Asking for assistance to connect one of the Samsungs MZRPA SSD out of a Vaio laptop
- its a single SSD with one flat cable connected to the mobo - its NOT LIF - its a proprietory
connector.
I have checked all posts regarding such type of SSD - its not a RAID part - its a single
SSD in this laptop - plus none of the shown SSD are similar to the one I have here -
it might be a newer pcb layout.
the ssd model: MZ-RPA1280/0SO - out of a VAIO VPCZ21M9E
I would need a ready to use adapter to SATA - I doubt that I am able to solder these tiny pins....
thank you
 Post subject: Re: samsung MZRPA SSD to sata
PostPosted: February 10th, 2016, 16:59
This is the picture of the SSD
PostPosted: February 10th, 2016, 17:11
Sure looks like a RAID ...
Peel off the sticker and show us the other side.
PostPosted: February 10th, 2016, 17:29
no raid - its a single pcb - (as told in my post - there is no 2nd module
connected to the cable and/or the mobo) - and the connector shown on
that picture is the only one.
but to be clear - on both sides of that SSD one finds memory chips
- peeling off the label only shows the memory chips of one side of that
module.
You might be right - if this single pcb is internally a combination of 2 ssd
into a raid and the pinout of that connector contains the rx/tx for 2 ssd ?
Thank you
PostPosted: February 10th, 2016, 17:36
All Google results for "MZRPA128HMCD" point to RAID. :?
This looks like it might have a second controller and SDRAM under the sticker:
http://g04.a.alicdn.com/kf/HTB1g9tcKFXX ... 2-Z215.jpg
PostPosted: February 10th, 2016, 17:59
yes, the one you referr to is most probably the "twin pack" of 2 ssd
used in a different type of Vaio laptop.
PostPosted: February 10th, 2016, 18:06
Can you show us the PCB without the sticker?
PostPosted: February 10th, 2016, 18:22
It has two serial numbers on the sticker... looks like it's an SSD RAID all built onto a single PCB to me. Very interesting, I've never seen this before.
PostPosted: February 10th, 2016, 19:23
The difference in the serial numbers is consistent with the difference in the example that I found. Moreover, there is discolouration under the sticker of the OP's drive which appears to be consistent with a second controller. That is why I am interested in seeing what caused it.
PostPosted: February 11th, 2016, 3:45
@fzabkar
sorry, I should have had a closer look to your link - i.e. the pictures
yes, you are right this is the type of ssd - your picture shows both
sides of the same ssd.
for my pics I need a while to find my camera
thank you
PostPosted: February 11th, 2016, 18:18
As Franc says, it's a RAID SSD module with a proprietary interface.
No adaptor exists as far as I know. If someone has made one, I want one! :-)
PostPosted: February 11th, 2016, 18:34
I have done one of these, it's not that hard to find the 2 pair of SATA channels and solder wires. In my case one of the drives had a few bad sectors.
Digitalsupport Data Recovery
https://digitalsupport.dk
PostPosted: February 11th, 2016, 18:57
Agreed, but an adaptor would save an awful lot of soldering! :-)
PostPosted: February 12th, 2016, 2:08
For sure an adapter would make life more easy, but i like it small :)
If these MZRPA shows up every month its time to rip the cable out af an Vaio an build something.
PostPosted: February 12th, 2016, 4:57
Here's a thread discussing a slightly different model ssd with a lot of relevant info. I would say there is enough to work out what to do. viewtopic.php?f=1&t=18418
PostPosted: February 14th, 2016, 5:25
Thank you all for advice - also for some PM - these Samsung raid ssd create some confusion ...
There are at least two different versions available for Vaio laptops - and this one is definitely
a double ssd built as raid on a single pcb with only one proprietory connector - not being a LIF
connector.
I do hope I solved the problem now (but only if the mobo is causing the problem) - I found
a used mobo which is reported to be ok.
The old laptop boots up correctly, even shows both raid ssd being ok during boot up - one
can access/modify cmos - can start Windows - but after a while it shuts down with a sever
error - blue screen reporting it has to protect the system and starts to count.
If the same happens with the other mobo - then its caused either by a faulty Windows on
the ssd - or the ssd isnt working ok at all - I´ll keep you informed - perhaps to report a
working solution and assist one or the other collegue in the forum now myself
PostPosted: February 14th, 2016, 7:43
So can you boot with a usb now and image the disk, I think this is a priority. If so maybe use a 3rd party tool to view eventlogs and find out why windows is borked. have you tried starting in safe mode? Also I haven't used it in a long while but I think there is still a logging startup mode
PostPosted: February 15th, 2016, 9:37
I Think you'll not need another motherboard. put a ubuntu on a stick with ddrescue on it, make an image to a usb drive and work from there.
http://www.rescue-it.se
