 Post subject: Pin Out Needed AGAIN
PostPosted: December 5th, 2016, 15:33
I think I know the answer, but anyone have this pinout?. Its similar in structure to the Mono SD Card with the pins exposed, but this has 12 pins on each side which doesn't match the ones currently available.
 Post subject: Re: Pin Out Needed AGAIN
PostPosted: December 5th, 2016, 17:35
I have for 2x6 pads on each side, but traces is other. But could fit. Top pad on second column from left is VCC?
PostPosted: December 5th, 2016, 18:04
Yes it is :-)
PostPosted: December 5th, 2016, 18:10
So pinout should be same.
PostPosted: December 5th, 2016, 18:26
Are you saying this is in VNR as I couldn't find it?
PostPosted: December 5th, 2016, 18:51
No, it is in my resources.
