 Post subject: Looking for pinout for monolithic SD Card
PostPosted: July 25th, 2018, 1:16
Hi, does anyone have the pinout for this kind of chip?
The problem with the chip is that a lot of the files are corrupted when you plug in the SD Card and read it. The SD Card detects fine and shows the correct size.
I made two different images of the SD Card using winhex, one copied forwards, and one copied backwards.
I compared them, and there was different information on each image.
Hoping to get a pinout to read the NAND directly and build the image manually.
 Post subject: Re: Looking for pinout for monolithic SD Card
PostPosted: July 25th, 2018, 2:42
I do not see this pinout before. Must be developed.
PostPosted: July 25th, 2018, 20:33
If you want I can develop a pin-out for it if you send it our way, I'm in the USA
jeremy at recovermyflashdrive.com
Recover My Flash Drive
Users browsing this forum: No registered users and 75 guests
