 Post subject: 4GB verbatim pendrive, error in 98%- can i reduce the vol
PostPosted: February 25th, 2019, 11:03
I have a 4GB verbatim pendrive, while formatting in Windows or thru SDCardformatter5, giving error in 98%- can i reduce the volume to 3GB.
 Post subject: Re: 4GB verbatim pendrive, error in 98%- can i reduce the vo
PostPosted: February 25th, 2019, 15:07
Why bother? You can probably get a new one for $3, or maybe even for free from some PC shop who gives them out as promotional items.
Certainly isn't worth my time trying to explain how to even attempt something like that. I can't imagine how it's worth your time.
PostPosted: February 25th, 2019, 18:48
ICBW, but you could create 2 partitions in Linux, and Windows would then only see the first partition.
PostPosted: February 25th, 2019, 21:29
I would reduce the volume to 0GB. With a sledgehammer.
Thanks FZABKAR, for the suggestion.
PostPosted: February 25th, 2019, 22:19
I would think that wear levelling would eventually thwart any attempt to avoid a bad area of NAND. Just because there may be bad cells at the 98% LBA mark doesn't necessarily mean that the physically adjacent cells, which may be potentially bad, occupy adjacent LBAs.
Users browsing this forum: No registered users and 100 guests
