 Post subject: Kingston datatraveler 4GB G3 problem
PostPosted: October 4th, 2019, 9:40
Hi all,
I've this pendrive with shorted controller. I need to recover data.
The controller ic is: SSS 6691 H1-M6C J4803-580B 1044
The NAND chip is: Phison HVPF4F5 115T051LF-3S-1
Because I don't have a nand reader, I tought to replace the controller. Is this right way?
If yes, the problem is to found a donor. Where I can search? Same pendrive is no longer available to buy on line.
Thanks.
Pak
 Post subject: Re: Kingston datatraveler 4GB G3 problem
PostPosted: October 4th, 2019, 10:36
Usually it is hard to find matching donor, and it is risky for data. Best way is chip-off method.
PostPosted: October 4th, 2019, 10:54
Thanks for your reply, arvika.
In order to invest..., which tools do you suggest for chip-off method?
PostPosted: October 4th, 2019, 11:17
For one case only? None. It not pay back. Better if you outsource the case.
PostPosted: October 5th, 2019, 4:55
+1
You’re looking at around $2100 for Soft Center reader and software licence, which is the best for this horrible controller.
http://www.flash-extractor.com/shop/
Or probably $300 to have it recovered professionally.
Users browsing this forum: No registered users and 122 guests
