 Post subject: PM983 3.84TB M.2 MZ1LB3T8HMLA-00007 ERRORMOD&1G,how recover?
PostPosted: June 1st, 2019, 3:20
I have a Samsung PM983 3.84TB M.2 drive specifically of model MZ1LB3T8HMLA-00007.
Since two weeks, it reports as firmware version "ERRORMOD". Apparently per @sourcerer and his research in http://www2.futureware.at/~philipp/ssd/ ... Manual.pdf , this means the drive attempts to start but faces early startup failure.
The drive reports as 1GB volume while really it's 3.84TB.
Do you have any suggestion for how to recover its contained data?
Not sure if Ace3K or MRT support it yet. Samsung has a SSD warranty team whose contacts are at https://www.samsung.com/uk/support/memo ... -warranty/ . Waiting for response of all these.
The drive is recent - 5 months use - and has been used only lightly.
Below is some Samsung DC tool output for your reference.
Your clarifications much appreciated!!
C:\Users\Username\Downloads>.\Samsung_SSD_DC_Toolkit_for_Windows.exe -L
Samsung DC Toolkit Version 2.1.W.Q.0
Copyright (C) 2017 SAMSUNG Electronics Co. Ltd. All rights reserved.
| Disk   | Path               | Model                      | Serial          | Firmware | Optionrom | Capacity | Drive  | Total Bytes | NVMe Driver         |
| Number |                    |                            | Number          |          | Version   |          | Health | Written     |                     |
| 0:c    | \\.\PHYSICALDRIVE0 | Samsung SSD 960 PRO 2TB    | ---serial here--- | 2B6QCXP7 | N/A       |  1907 GB | GOOD   |  0.01 TB    | Samsung NVMe Driver |
| 1:c    | \\.\PHYSICALDRIVE1 | SAMSUNG MZ1LB3T8HMLA-00007 | ---serial here--- | ERRORMOD | XNUSRG29  |     1 GB | N/A    | N/A         | Samsung NVMe Driver |
C:\Users\Username\Downloads>.\Samsung_SSD_DC_Toolkit_for_Windows.exe  -d 1:c -NG -l
Estimated Life Time: 0 %
[Success] Get Log Page Feature completed successfully
C:\Users\Username\Downloads>.\Samsung_SSD_DC_Toolkit_for_Windows.exe  -d 1:c -NG -s
Disk Number: 1:c | Model Name: SAMSUNG MZ1LB3T8HMLA-00007 | Firmware Version: ERRORMOD
| Bytes   | Description                             | Value                              |
| 0       | Critical Warning                        | 0x00                               |
| 2:1     | Composite Temperature                   | 0x0000                             |
| 3       | Available Spare                         | 0x00                               |
| 4       | Available Spare Threshold               | 0x0A                               |
| 5       | Percentage Used                         | 0xFF                               |
| 47:32   | Data Units Read                         | 0x00000000000000000000000000000000 |
| 63:48   | Data Units Written                      | 0x00000000000000000000000000000000 |
| 79:64   | Host Read Commands                      | 0x00000000000000000000000000000000 |
| 95:80   | Host Write Commands                     | 0x00000000000000000000000000000000 |
| 111:96  | Controller Busy Time                    | 0x00000000000000000000000000000000 |
| 127:112 | Power Cycle                             | 0x00000000000000000000000000000000 |
| 143:128 | Power On Hours                          | 0x00000000000000000000000000000000 |
| 159:144 | Unsafe Shutdowns                        | 0x00000000000000000000000000000000 |
| 175:160 | Media and Data Integrity Errors         | 0x00000000000000000000000000000000 |
| 191:176 | Number of Error Information Log Entries | 0x00000000000000000000000000000009 |
| 195:192 | Warning Composite Temperature Time      | 0x00000000                         |
| 199:196 | Critical Composite Temperature Time     | 0x00000000                         |
| 201:200 | Temperature Sensor 1                    | 0x0000                             |
| 203:202 | Temperature Sensor 2                    | 0x0000                             |
| 205:204 | Temperature Sensor 3                    | 0x0000                             |
| 207:206 | Temperature Sensor 4                    | 0x0000                             |
| 209:208 | Temperature Sensor 5                    | 0x0000                             |
| 211:210 | Temperature Sensor 6                    | 0x0000                             |
| 213:212 | Temperature Sensor 7                    | 0x0000                             |
| 215:214 | Temperature Sensor 8                    | 0x0000                             |
C:\Users\Username\Downloads>.\Samsung_SSD_DC_Toolkit_for_Windows.exe  -d 1:c -NG -e 4
| Index | Bytes | Description                          | Value              |
| 0     | 7:0   | Error Count                          | 0x0000000000000009 |
|       | 9:8   | Submission Queue ID                  | 0x0000             |
|       | 11:10 | Command ID                           | 0x004E             |
|       | 13:12 | Status Field                         | 0x4212             |
|       | 15:14 | Parameter Error Location             | 0x0028             |
|       | 23:16 | LBA                                  | 0x0000000000000000 |
|       | 27:24 | Namespace                            | 0x00000000         |
|       | 28    | VendorSpecific Information Available | 0x00               |
|       | 39:32 | Command Specific Information         | 0x0000000000000000 |
| 1     | 7:0   | Error Count                          | 0x0000000000000008 |
|       | 11:10 | Command ID                           | 0x000C             |
|       | 13:12 | Status Field                         | 0x4004             |
|       | 15:14 | Parameter Error Location             | 0xFFFF             |
|       | 27:24 | Namespace                            | 0x00000001         |
| 2     | 7:0   | Error Count                          | 0x0000000000000000 |
|       | 11:10 | Command ID                           | 0x0000             |
|       | 13:12 | Status Field                         | 0x0000             |
|       | 15:14 | Parameter Error Location             | 0x0000             |
| 3     | 7:0   | Error Count                          | 0x0000000000000000 |
 Post subject: Re: PM983 3.84TB M.2 MZ1LB3T8HMLA-00007 ERRORMOD&1G,how reco
PostPosted: June 2nd, 2019, 3:04
I doubt that there is an electronic failure, but we could at least measure the onboard supply voltages to confirm that they are within spec. Could you upload hi-res photos of each side of the PCB?
The exercise may not help you, but it may help others.
PostPosted: June 5th, 2019, 3:08
@fzabkar, find attached high res photos of the PM983.
PostPosted: June 5th, 2019, 4:03
I would measure the voltages at V1-V7, Vboost, and the voltages across the indicated capacitors. Also measure the voltage across the large array of backup capacitors.
I don't expect that there will be any problem, but it's a relatively easy check.
PostPosted: August 12th, 2020, 16:47
Have you found a solution?
I have the same problem with a brand new Samsung MZ1LB1T9HALS-00007 SSD 1920GB PM983 M.2 PCIe
only - 1Gb !?
Users browsing this forum: No registered users and 33 guests
