 Post subject: Anyone seen this Controller?
PostPosted: September 21st, 2020, 18:50
Anyone know the pinout for this controller?
IDE - 5019BSC-1
After some research it appears it may be an unbranded Alcor, but that is as far as I have got.
NAND chip is just a blob under hard conformal.
Any help would be appreciated.
 Post subject: Re: Anyone seen this Controller?
PostPosted: September 21st, 2020, 21:50
It looks like the PCB is laid out for two controllers, "AU" (Alcor Micro) and "FC" (FirstChip). Perhaps you could find a known "FC" controller in a 24-pin package which matches the 5V, ground, 3.3V (?) and Data +/- pins? Then you could work backwards and translate the pinout of the IDE chip (like the Rosetta Stone).
PostPosted: September 22nd, 2020, 7:34
I had very similar one. Sadly it was dymanic XOR.
Pinout should be easy to find.
odzyskiwanie danych
PostPosted: September 22nd, 2020, 8:19
i had one as well, reversed the pinout (sent to Tim already), but as far as i can recall the job was stuck somewhere else. Maybe due to dyn xor as Melvin said...
PostPosted: September 22nd, 2020, 9:54
Thanks for the replies. As pepe said he sent me his pinout (much appreciated), so I will try today and let you know the outcome.
PostPosted: September 22nd, 2020, 13:50
Well,
I Would Love To Nail This Case If i Had It :D .
PostPosted: March 3rd, 2021, 4:50
Hi, did someone find the layout for this controller? I would need it to.... thanks
PostPosted: March 4th, 2021, 17:16
http://www.flash-extractor.com/library/ ... 94_da__1x1
This IDE5019 appears to be a re-badged AU controller.
Users browsing this forum: Ahmed Saeed and 107 guests
