 Post subject: Kioxia KBG30ZMV512G - dead?
PostPosted: November 12th, 2021, 15:49
Hi
I have a "Kioxia KBG30ZMV512G" in for data recovery.
It's not detected by a Windows laptop/PC.
I have measured the voltages as per:
http://www.hddoracle.com/viewtopic.php? ... 054#p22120
Results:
V1 = 1.8V.
V2 = 1.2V.
3.3V (near V2) is present.
3.3V is present.
I have also checked the EMI filters (for continuity) and found no issues.
I can't find a controller on this SSD. Does this SSD even have one on the SSD PCB?
I have plugged this SSD into a Linux laptop (using a external NVME to USB caddy) and have some "dmesg" output.
Does anyone have a clue what the dmesg output means?
Is chip off recovery *even* possible for this SSD?
I can send this SSD to a data recovery specialist, but I don't want to waste time on this if this would be a pointless exercise.
What's peoples opinion on this?
Thanks, David
kioxia ssd - dmesg output.txt [2.24 KiB]
Downloaded 440 times
 Post subject: Re: Kioxia KBG30ZMV512G - dead?
PostPosted: November 12th, 2021, 16:10
It's an "SSD on a chip":
https://www.reddit.com/r/datarecovery/comments/jdog67/recovering_data_from_toshiba_toshiba_kbg30zmv512g/g99t204/
PostPosted: November 12th, 2021, 17:15
So, utterly stuffed then?
Users browsing this forum: No registered users and 103 guests
