 Post subject: SanDisk SSD PLUS 240GB
PostPosted: July 23rd, 2020, 7:44
Model : SanDisk SSD PLUS 240GB
Serial :
Firmware : UF4500RL
Capacity : 240 GB (468 877 312)
proc sandisk 20-82-00469-2
SSD is not supported IS pc3000 ssd utilities.
tool supported?
Help me!
Нет ничего невозможного
 Post subject: Re: SanDisk SSD PLUS 240GB
PostPosted: July 28th, 2020, 3:26
Banned User
You got your solution or not?
PostPosted: July 28th, 2020, 7:56
not solution!
PostPosted: July 30th, 2020, 2:25
Banned User
I have the same issue. Hope be supported in the next update..
PostPosted: September 27th, 2022, 16:43
http://flash-extractor.com/library/SanD ... 98_b3__4x1
PostPosted: September 28th, 2022, 4:23
LostDataSa wrote:
http://flash-extractor.com/library/SanDisk/20-82-00469-2/20-82-00469-2__45_3c_98_b3__4x1
You're 2 years late and these drives are now supported under PC 3000 ssd.
PostPosted: September 28th, 2022, 4:27
But reading them in PC3k is in 90% pointless. Sandisks work till they are in really bad condition.
odzyskiwanie danych
PostPosted: September 28th, 2022, 4:45
I know that the ssd plus with sandisk nand are like this having had one in recently, but I thought those drives with the mavel controller or other brand nand were fine?
PostPosted: September 28th, 2022, 14:31
As I know this controller is not supported by PC3K.
PostPosted: October 5th, 2022, 3:34
Yeah, chip off is only option for those, no PC3K support.
PostPosted: October 5th, 2022, 8:17
A very long and painful process, as I've recently discovered.
Recovery Force Data Recovery
PostPosted: April 1st, 2023, 10:53
Well,
Were does it state its supported ?
PostPosted: April 1st, 2023, 15:39
Amarbir[CDR-Labs] wrote:
Well,
It isn't - I didn't see the OP had specified the sandisk controller rather than once of the many others found in the drives.
