 Post subject: Samsung CM871a - BSY - short points help
PostPosted: July 21st, 2023, 8:44
Hi all, I have this Samsung in. It looks to be BSY. I can see that it's supported by PC3K v 7.1 and above I think.
Can someone help please with confirming short points. I thought it would be lower2 on bottom left but that didn't work.
Many thanks
Louis
 Post subject: Re: Samsung CM871a - BSY - short points help
PostPosted: July 21st, 2023, 8:53
Many thanks
Louis
Actually, I just measured and the bulk of those pins are approx 1.3v, the closest to top is zero, so it may be at the other end. I'll guess I 'll try it later unless someone knows for sure.
PostPosted: July 21st, 2023, 11:09
i would vote for the bottom two.
PostPosted: July 21st, 2023, 11:41
Multimeter was wrong or i need glasses.
from top
1) GND
2) NVALUE
3) 1.8v
4) 1.8V
5) 1.8V
6) 1.8V
7) 1.8v
can get drd dsc but not into safe mode when i short pin 7 to GND
PostPosted: July 21st, 2023, 13:17
yes, right, those pins are not for ROM mode, one of them is Vref on the bottom.
then idk where ROM mode pins are on this one, perhaps post a pic without label and the other side as well
PostPosted: July 21st, 2023, 20:58
I don't have PC3000. I thought it told you what pins to short?
PostPosted: July 22nd, 2023, 4:44
Yes it does, but I think this model must be an outlier as the pins indicated do not work.
Beginning to think this is a non supported after all. CM871a, might not be the same CM871
PostPosted: July 22nd, 2023, 4:51
I was trying to find a spec for the Flash chip, but it looks like a Samsung proprietary. I was reading on Ace manual about finding Data pins to short but it's BGA and it's not going to be easy without a proper pin out.
Thanks for taking a look, but likely going to return this to customer as they are leaving for Germany shortly.
PostPosted: July 22nd, 2023, 23:06
-000L7 is Lenovo, maybe they have behind their service/paywall specs. Unlikely, but who knows?
I dumped several datasheets https://files.hddguru.com/download/Datasheets/Samsung/ and maybe they contain the info you're searching on a similar model for this CM/PM871
PostPosted: August 1st, 2023, 11:14
Thanks for sharing those. Unfortunately the customer had to collect and take the machine back home to Germany which meant we couldn't look at it further.
